![]() | Home > Puma (Tdci) > Brodit Prolip mount for Mobile Phone Cradle |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 ![]() ![]() ![]() |
I'm looking at getting a mount for a mobile holder.
Always liked the Brodit stuff and was looking at the Puma ones. I know they do the one that sits up on top of the dash, but don't fancy blocking the vents off. So the other option is this one that clips behind the bottom of the centre console. ![]() My only concern is that it's very near the headunit and interference may be heard out of the speakers. Just wondering if anyone else uses one of these? Or of course any other ideas! ![]() 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
![]() Since posting, I have been looking at the vent mount. I assume you mean this one ![]() As I've got a Galaxy S3, which isn't the smallest phone, I would probably mount it horizontal. I could also use it to watch videos and of course could actually email/text using the voice feature (which works via BT thru Headunit), therefore, being higher up would actually be better. I was thinking that I could place a RHD mount on the left vent which gives a bit more space. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
marklockett2103 Member Since: 08 Feb 2011 Location: West Sussex Posts: 32 ![]() |
ive got the brodit one, dont get any interference from iphone 4s
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1233 ![]() ![]() ![]() |
Hi, Like BigRuss I have two mounted on each upper vent. However, you need to be careful with what phone you are putting in the cradle. Both the ms, my son and myself have I-Phone 4s and if you have heat coming out of the upper vents they get hot and start shutting down with warnings to say they are shutting down for protection as the processor is getting too hot.
Other than that they are a lot easier to read and great for satnav & inclinometer apps. |
yes thats the one, I also bought a mount that has power and run the lead behind the centre console and left enought free so I can rotate the mount 90 degrees if needed ![]() Also they have never jumped out offroading ![]() 2011MY 110 XS USW Black |
Ah, now that's interesting.
I have various options with the S3. I'm going for full active which narrows it down to 2 unless I go cheapskate and get a cig lighter one and bastadise it. ![]() or ![]() The second one is a LOT more expensive, and looks a bit fiddly. If I can get away with the first one it'll cheaper and less fiddly, but not sure it'll stay in place in landscape mode. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
I went for the first one without the top bit to hold it in, but I don't normally drive with it on the side but they are a tight fit in general. Russell
Thanks Russ, it saves a big load of cash going for the top one. If I have any issues, I can always make it a tighter fit. Craig Rogers
Inigo Member Since: 13 Nov 2011 Location: Kent Posts: 625 ![]() ![]() ![]() |
I use a Brodit holder cobbled to a dashmount bracket from these guys: http://www.chameleondirect.co.uk/index.php...cts_id=895
Original brodit holder in that position relies on adhesive to hold it in place and I've had the centre console out so many times fiddling with adding extra bits that it didn't last very long. The one linked above is metal and held in place by the bolt that holds the fascia on. It does leave the fascia bulging slightly where it cannot seat properly. No interference issues. I used the power supply from an active brodit holder for a previous phone. Same plug that fits my Galaxy S2 and use the additional socket on the power supply to power my Galaxy Tab for Sat Nav. When I turn off ignition, I get a message on the S2 saying that charging has paused due to overvoltage. I get this in another car using a similar system, so it might be the phone, or the use of the older generation power supply, but it works well enough to not bother changing at the moment. |
