Home > Maintenance & Modifications > Additional Heater
sweatysock
United Kingdom 2007 Defender 110 Puma 2.4 CSW Indus Silver
Additional Heater
Hi, My Defender 90 300tdi is without doubt the coldest Defender I have ever had...and Mrs Sweatysock is no longer up for it. So I was wondering what others solutions are in terms of auxiliary heating and the need for additional battery power etc. Oh by the way, I already have a grill muff to try to accelerate things
I am not up for spending a fortune but interested in views, thanks Sweatysock
110 CSW TDCI (Puma) 2007
Post #210799 12th Feb 2013 8:37pm
SGH
What is it Hardtop, County, Truck cab?
Post #210800 12th Feb 2013 8:39pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
How about a couple of mains powered tube heaters to warm the inside before you get in it then run them off of an inverter once on your way.Anyone tried anything similar ? 2005 Td5 90 XS
Steve
Post #210802 12th Feb 2013 8:40pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
1st question. Does the engine get upto temperature in a reasonable time. If not, then your thermostat could be faulty Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #210803 12th Feb 2013 8:40pm
nidge n
on a slightly different subject, does anyone have a solution to get warm air to the rear of a 110? sorry to hijack
Post #210809 12th Feb 2013 8:48pm
sweatysock
It is a county.
Good question re thermostat as I have not experienced this before in other Def's. In the summer it warms quickly but (as I have found) in the winter it seems to take forever and if at all in slow speeds in really cold weather....is this not the norm for a 300 ?. Sweatysock
Post #210812 12th Feb 2013 8:55pm
JWL
I used to have a 600watt tube heater in my 110 station wagon, plugged into an extension overnight then the inverter when driving. It was better than nothing but needed more, yes the windows were free of frost but it was still cold. You I think you need at least 1000watts of heat source. If your engine heater is up to scratch when driving put a electric heater in overnight even if you switch it on an hour or so before you use the motor.
I now have an Eberspacher air heater, it's just the job. I switch it on 20 minutes before I want the motor and the windows are clear and it's really toasty plus left on the lowest setting compliments the dire heating a Td5 gives when on tick over in slow traffic etc. They do come to those that wait for the right price, it wasvon my wish list for the past 10years but well worth the wait!
Post #210815 12th Feb 2013 9:01pm
sweatysock
and how does the standard charding cope with additional requirements ? do you need a 2nd battery ? Sweatysock
Post #210818 12th Feb 2013 9:06pm
SGH
My truck cab 300tdi gets toasty so you could always for the winter put screen between front and rear so you are just heating up the front.
Post #210823 12th Feb 2013 9:14pm
JWL
When I was using the tubular heater as an overnight heat source I would use an extension lead from the garage, when the engine was running then I would use the inverter. Occasionally the inverter was being used with no engine running and at the time I only had one battery. I was confident that my motor was a good starter but also reliant on the fact that the inverter(Maplins purchase) had a low battery shutdown facility. I have now added a second battery and run all my ancillaries off that, which with the engine off is isolated from the starter battery. I must admit that I did feel concerned that just relying on the starter battery could have ended in tears but it didn't happen.
Post #210851 12th Feb 2013 10:54pm
BigWheels
This is what you want - Webasto!  Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #210853 12th Feb 2013 11:02pm
