![]() | Home > Off Topic > Do I Need a Fuse Near the Batteries. |
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 ![]() ![]() ![]() |
Would put a fuse near battery just in case of a direct short ! Saves having a fire
Luismi Member Since: 04 Nov 2010 Location: Cotswolds Posts: 178 ![]() ![]() ![]() |
Can you tell the make and model of your regulator/ controler, and i this has tw isolated output for each battery otherwise
you seem to be conecting in parallel the batteries with a small section cable. I say small section cable as thoses panels will produce up to arround 3.3 Amp. Cheers |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026 ![]() ![]() |
Souinds as though I may need fuses.
This is the controller http://www.sunstore.co.uk/EP-Solar-Duo-Bat...v-10A.html I will probably wire one panel up to the other so that only one lead goes into the controller! Sunstore are supplying the cable also. Good thick stuff apparently. These are the panels... http://www.sunstore.co.uk/12v-20w-Monocrys...Panel.html |
Very nice, two isolated output.
![]() Good kit Zagato Cheers |
Glad I got it right Luismi, thanks. A couple of fuses and job done then
![]() ![]() ![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Hi Zag, study your swichboard carefully... At first I thought also my boat switchboard did not have fuses, but then I discovered the switches were with incorporated automatic fuses! Those american boat builders were way ahead 40 years ago ![]() 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Oh thanks I'll have a proper look
