Home > In Car Electronics > Focal Speaker Upgrade
Page 4 of 4 <1234
Tiger
Few images here:
https://www.defender2.net/gallery/thumbnails.php?album=1095
Also added a aux fuse box to support the sub:
https://www.defender2.net/gallery/thumbnails.php?album=1096
tags are backards
Post #210197 10th Feb 2013 5:51pm
ethanicus
2014 Defender 90 Puma 2.2 XS CSW Corris Grey
Thanks buddy. All corrected.
Post #210200 10th Feb 2013 5:56pm
Tiger
The Alpine Sub looks neat and a good fit, would it not mount the other way up?
(Upside down writing would annoy me)
Post #210338 11th Feb 2013 8:39am
ethanicus
Morning,
Its physically the right way up but the logo isn’t. Ion the land rover version they print the logo the other way round. I have ordered a sticker to cover it up. If I mounted the other way loads of crud would full into the unit 
Factory unit looks like this:
Post #210353 11th Feb 2013 10:49am
Likeomg
i think i need a bigger sub... to keep up with the focals that is, there mad!
Post #210364 11th Feb 2013 12:03pm
barbel jim
I know exactly what you mean. Rolling with laughter Rolling with laughter
Just have a play around though, I turned my amp down to about a third, and ths gain on alpine active sub all the way up and set the filter low low low. Works quiet well now, but it also alters depending on music and formats. Going for a proper sub set up is nice, but would be another £4-500 and then not as practical for me.
I am still undecided but by playong around have got the sound alot better Thumbs Up
Post #210365 11th Feb 2013 12:11pm
mlightfoot
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
SGH wrote:
I have same front upgrade ready to fit and bought iBus 2.1 under seat sub to add to the system.
Fitted sub today and decided to run the cables under vehicle rather than inside to make a neater install.
Where did you fit the crossovers as not much room on offside
Simon
Looking at fitting this and had hoped to locate it on the back of the cubby but it seems too long. Where did you locate the iBus 2.1?
Thanks M
Post #447506 19th Aug 2015 8:34pm
mcma1
I have a Focal kit to fit in the front... read over this but can you give me a guide to wiring these, what connectors do i need to run and get for example? How do you coneect up the cross over?
Andy
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #496624 26th Jan 2016 3:18pm
mcma1
ethanicus wrote:
Rears = Straight swap
Fronts
Tweeters are pre wired but need connecting to the crossover (pictured)
Existing speaker connection need changing for forks and simply connect to the crossover . Then create a small link cable for the mids.
Velcro crossover to inside of dash. All installed in under 1.5 hrs.
When I dyno mat the rear I will replace the speaker cable as the factory is very thin.
I take it the 2 wires on the left are the tweeters? What are the other connections wiring? Andy
2014 Corris 110 SW
LS3 V8 build...
Post #496628 26th Jan 2016 3:25pm
Morepower
New Zealand
From left to right (as your looking at it) Tweeters, Mid and Input...
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #496655 26th Jan 2016 4:37pm
mcma1
Thanks Tim,
Sorry for the daft questions but the input wires come from where?? Do you have to make up new cables from the cross over to the focal speakers, and then ditch the LR cables to the current speakers??
Andy Andy
2014 Corris 110 SW
LS3 V8 build...
Post #496694 26th Jan 2016 5:55pm
mcma1
Are the inputs just the factory tweeter/woofer positives and negatives?? Andy
2014 Corris 110 SW
LS3 V8 build...
Post #496704 26th Jan 2016 6:17pm
Morepower
New Zealand
The tweeters come with wire attached.. (all you have to do is put a connector on)... You have to make up the mid range cables and you just use the mid speaker wire with replacement connections for the inputs..
Hope that makes sense!!
Post #496715 26th Jan 2016 6:39pm
mcma1
Post #496757 26th Jan 2016 7:57pm
Page 4 of 4 <1234
