Home > Puma (Tdci) > Clutch question!
Gabriel Boff
Brazil 2009 Defender 90 Puma 2.4 XS CSW Tonga Green
Clutch question!
Hi!
Some news about the clutch's springs problems?
My 08/09 Puma, which according to it's VIN won't have the problem clutch had it's clutch replaced with only 25000 km, some notices if this "new" clutches are working properly?
Isn't this clutch problem a inadimissible problem for a Defender?
LR know about this amout of clutches changed under warranty?
What LR are doing to permanent solve this problem?
Sorry about the massive questions, but her in Brazil we don't have informations and the dealers even know that the clutch is an big and persistant problem in all world!
regards
Post #20998 31st Dec 2009 8:41pm
MacDefender
Brazil 2007 Defender 110 Puma 2.4 CSW Zermatt Silver
Helloo Gabriel.
I'd just replece my 2007 def clutch (all parts) after only 30.000 km
Working very good as far as I know.
Good luck Big Cry
Post #84902 17th Aug 2011 7:47pm
Gabriel Boff
Pois então!
Um caxiense no forum!
me contata em pvt: gabriel@mepel.ind.br
abraço!
Post #84914 17th Aug 2011 9:07pm
MK
Just an oppinion, but probably a HD, good quality dual mass flywheel would have been a better solution. The actual dual-damper friction plate is the cheap LR solution. Puma 110" SW
Post #84934 17th Aug 2011 9:54pm
CGAUER
Brazil 2005 Defender 110 300 Tdi SW Epsom Green
Gabriel,
a close friend just replaced his 110 y08 clutch for the third time. Not only this, but he is also on the 2nd engine, gearbox, turbo + exhaust manifold. So far everything covered under waranty...
Good luck.
Clemente Land Rover Defender 110 SW 300tdi 2005
Suzuki Jimny 1.3 VVT 2010
www.cgauer.com.br
www.vimeo.com/25710554
www.flickr.com/cgauer/sets
Post #84960 17th Aug 2011 11:38pm
Eduardo
Gabriel,
I have the new one since the 30,000 km replaced under guarantee after the springs falling down from the clutch plate.
Now, with 120,000 km I didnt see any problem.
Cheers Eduardo
Post #85036 18th Aug 2011 2:57pm
Glynparry25
On my MY09 I have covered 26,000 miles with no clutch problems (Touch wood Whistle ).
Glyn Dog Sheep
Post #85056 18th Aug 2011 4:53pm
Landyrob
United Kingdom 2012 Defender 110 Puma 2.2 HT Alpine White
i still have the original clutch in my TD4 (07) done 70'000km, just a little rattle while running in neutral, but that's a defender. Wink LANDROVER Defender Best 4 x 4 x Far
Defender TD4 90 Hardtop 2.4
Defender TD4 110 Hardtop 2.2
Post #85088 18th Aug 2011 8:34pm
I would rather have the rattly thing in the Puma than the awful dual-mass arrangement of the TD5 any day.
The TD5 dual mass flywheel is an abomination.
Post #85180 19th Aug 2011 11:44am
