Home > Maintenance & Modifications > Fitting a tracker
Page 2 of 9 <123456789>
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
Dave-H wrote:
davew wrote:
Skytag isn't proactive. It's only of use after you've noticed the vehicle has gone and you can't really do anything with it until you have a crime number.
Not true.
Have a read up http://www.skytag-gps.co.uk/
You can have an upgrade [only £4.00 a month extra] so it alerts you every time it leaves a set area [Geozone]. On leaving it will send you an e-mail, text your mobile and ring your landline Cool
Skytag also monitors the battery feed to the unit, if its disconnected [by theiving scum cutting the earth cable] again it will send you a mail/text/phonecall .... well worth the subscription alone Thumbs Up
The crime number is not essential .. phone then first [before phoning the old bill] and by the time you have reported it to plod, skytag will already be on the case, saving vital minutes Wink
You cannot set up an ad-hoc stockade with Skytag but you can set up a general stockade for a significant extra cost. For example, if I were to drive to Leeds I cannot, with Skytag, phone them up and ask that they put a 300metre stockade on until I finish shopping and alert me by text if the vehicle receives a shock or moves outside the stockade area I have defined during that time. You CAN do that with the OP's unit. I did point this out quite clearly in my post as well as stating that you could use a more limited version with Skytag.
With a Skytag unit the first I would know that anything was amiss was when I returned to the car park and found the vehicle missing. Extra minutes spent getting a crime number fade into insignificance when compared to the time it might take you to realise your vehicle has gone.
Re the crime number both the serial number card you get with the Skytag units and the people you talk to when you register them state that you must get a crime number first, then call Skytag.
 http://www.yorkshireoffroadclub.net/
Post #209853 9th Feb 2013 5:06pm
You are right Dave regarding the limitations of the geozone with Skytag but Skytag will accept your call without a crime number it just helps when they contact the police.
In the same scenario that you have outlined you would still have to phone the police and go through exactly the same process to report the crime and then try to pass the location to them (possibly off the same phone you are making the call from).
Each system has its plus and minus points, I don't believe either is the better one
You pays your money and makes your choice
Post #209865 9th Feb 2013 5:22pm
davew
I disagree, there is a better solution...
FIT BOTH Smile http://www.yorkshireoffroadclub.net/
Post #209871 9th Feb 2013 5:32pm
Bow down Thumbs Up
Post #209872 9th Feb 2013 5:34pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
FIT BOTH Smile
Whistle
You been peeking? Thumbs Up Guns and Landrovers .... anything else is irrelevant.
Post #209880 9th Feb 2013 6:13pm
Dobby
ZeDefender, you'll probably find you can turn the GPS off, then set it to re-enable when the unit detects movement. Most of the cheap Chinese GPS trackers will do that, as will the skytag unit. They all have a tremble switch in to detect towing.
The battery problem should really be an issue, the battery is designed to keep the unit going when the vehicle power is cut. It should also alert you to this with a text. The idea being you wire it into a permanent 12v supply, then is the thieving sc*m disconnect the main vehicle battery, the backup internal battery takes over.
IIRC the skytag units are the same 'type' of GPS tracker you can but on the Internet, from China. The difference being they're centrally monitored/responded to.
HTH?
Post #209883 9th Feb 2013 6:26pm
ZeDefender
Hi Dobby Smile
How's my favourite town then?
Yeah - I agree - after reading davew's post again, it occurred to me to get a replacement unit (like for like) with decent battery life (clearly something's not quite right), although wired into the car it's been fine all week. I'll dig it out tomorrow.
I think I should stress how powerful these inexpensive things are. If you set it to pick up vibration and detect vehicle movement:
1) If the car vibrates it sends you an SMS
2) If the car moves position it sends you another SMS telling you where it is.
3) You can then tell it to send it's position at set (even 5 second) intervals until you track it down.
2*) If you don't get an SMS saying the car has moved position you can assume it was just hit by a blind squirrel or something. Then ask it where it is and get peace of mind.
Some versions also have a microphone (a good one) so you can hear what's going on inside the car and decide if it's dodgy, e.g. if your children borrow it... er, let's not go there Whistle
Adding to the above, you can also tell it to alert you if it exceeds a certain speed - also useful if you suspect your offspring is a speed demon...
As a non-UK resident, my options are limited (there are German companies but $$$$$$$) - I think it's a pretty good solution Thumbs Up
Matt Tell someone you love them today because life is short.
Post #209894 9th Feb 2013 7:16pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Matt,
I just ordered one, seems silly not to.
Would be interested to know how you wrote the app, I have an Android phone so would need to code it myself. A nice little project for me..Smile
Simon
Post #209896 9th Feb 2013 7:26pm
ZeDefender
I didn't write the app (wish I could do such things) - that was davew Thumbs Up
Simon - check which version you're getting - some only have vibration or microphone etc. (depends how much you pay, sadly). Tell someone you love them today because life is short.
Post #209899 9th Feb 2013 7:34pm
couplands
Oops, sorry davew, got confused..!
Any help/pointers appreciated.
Simon
Post #209900 9th Feb 2013 7:35pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
I have a number of these in my Defender and they are extremely accurate. They work under cover too. Hard wired with battery back up, mine have been installed since last December with no issues whatsoever.
I like that I can monitor the vehicle myself, I am in control Very Happy
Steve
Post #209901 9th Feb 2013 7:35pm
couplands
Matt,
I ordered the one in your post, I'd been watching the same model on eBay but from another supplier at a higher price.
Does that one have a microphone/vibration sensor..? Edit: I checked the spec it it appears to have the voice surveillance option...
Simon
Post #209910 9th Feb 2013 7:50pm
Dobby
ZeDefender wrote:
Hi Dobby Smile
Aha.. You were a local? Probably a lot busier than you remember, can't move for new houses and cars these days. And then of course the Para's are in toon too. Surprised
Back OT; I've got one of the GPS/GSM units from dx.com. Very useful. The only problem I have is finding somewhere sensible to fit it, as my 90s a rag top. They're not waterproof though, and damp seems to knacker them.
Ooh now there's an idea the scroats haven't got to yet.. Hiding nicked cars in ponds.
Post #209918 9th Feb 2013 8:14pm
davew
Simon
It's a pretty simple app that composes the text messages for you. It stores your device phone number and password and has a button to turn on/off most of the features by composing and sending the appropriate message.
For the stockade it uses the phone's current position and allows you to set the radius for the stockade. It then uses that to calculate the top/left and bottom/right coordinates and composes the message. To make it easier it displays a map view with a rectangle overlaid to show the selected area. It also shows the current accuracy of the phone's gps. http://www.yorkshireoffroadclub.net/
Post #209949 9th Feb 2013 9:27pm
ZeDefender
Hi Simon
There are several different models. The one I posted was the closest one I could find with English text to the one I bought in Germany but mine has both a vibration sensor and voice surveillance built in. If the UK version I posted doesn't have both, then sorry for any confusion Embarassed
This is the German version I bought (but mine was cheaper):
http://www.ebay.de/itm/GPS-Tracker-Peilsen...20b05781b0
I've just been scouring UK eBay for exactly the same one but I can't find it - they market them differently here Rolling Eyes Tell someone you love them today because life is short.
Post #209957 9th Feb 2013 9:52pm
