Home > Other Site Sponsors > F/S Job lot of Interior LED Lights
Page 9 of 14 <123 ... 8910 ... 121314>
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
It's the angle that you approach the sprung holder to the back plate if you manage to touch the holder and back plate with the end cap it will blow the fuse as its a dead short
Steady hand or as said pull fuse Thumbs Up
Hall way through one of each fitted
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #208760 5th Feb 2013 11:34pm
Killer90
Site Sponsor
Thats a great comparison Lee Thumbs Up
Here are my ones fitted to a local customers 110 at night Mr. Green
 CSK Automotive
www.cskautomotive.co.uk
Post #208774 6th Feb 2013 12:40am
TR51
France 2014 Defender 110 Puma 2.2 SW Corris Grey
Sorted mine today (after some advice from Chris Embarassed ) and very happy Thumbs Up
Cheers Chris
Post #208842 6th Feb 2013 11:49am
Thud
United Kingdom 2008 Defender 90 Puma 2.4 SW Zermatt Silver
Haven't fitted mine yet. How do I not blow my fuse?
Post #208858 6th Feb 2013 1:20pm
x-isle
Overide the switch to turn the light off before removing the old bulb.
If there is a perm live up there, the only thing that will blow the fuse is touching earth, so that can only be the other side of the connector which is what the door switch earths. The power switch will either pass the earth down to the door or to perm earth (switch set to on).
Other than that, just be careful....? Thumbs Up Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #208859 6th Feb 2013 1:23pm
The issue is that the backplate of the light fitting, which is permanently live, is quite large, so it's very easy to create a short between it the earth terminal. Taking the fuse out before fitting is an easy solution but if using the springy adapter to the typical panel-type LEDS then I was worried that it might move or flex in use and still make contact later. Hence my suggestion of a square of insulation tape. That's probably less of a concern with a 'fixed' bulb. Darren
Post #208874 6th Feb 2013 1:43pm
x-isle
But if the light is switched off, there is no earth surely?
As far as I know, the interior light is earth switched.
If the switch is set to "door", the door pins earth the light.
If the switch is set to "on", the switch earths the light
If the switch is set to "off", there is no earth present.
I could be wrong, and usually are, but if the light is off, then there is no way of earthing it. Craig Rogers
2007 Puma 110 XS
Post #208880 6th Feb 2013 1:51pm
Thud
Oh I'll just say a little prayer.
Post #208898 6th Feb 2013 2:30pm
Killer90
Site Sponsor
Just take it easy when fitting them Thumbs Up CSK Automotive
Post #208901 6th Feb 2013 2:37pm
x-isle
Or to be fully safe, disconnect the battery and wear a rubber suit.! Rolling with laughter Craig Rogers
2007 Puma 110 XS
Post #208902 6th Feb 2013 2:39pm
Killer90
Site Sponsor
Rolling with laughter Bow down i can imagine it now, what the neighbours must think Whistle Rolling with laughter CSK Automotive
Post #208921 6th Feb 2013 3:29pm
Don't tell me your not tempted if it was white Chris. Whistle Twisted Evil _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #208947 6th Feb 2013 4:53pm
WarPig
Received mine today Thumbs Up
Post #208963 6th Feb 2013 5:26pm
Killer90
Site Sponsor
good to hear mate Thumbs Up CSK Automotive
Post #209003 6th Feb 2013 7:28pm
Killer90
Site Sponsor
Maybe Whistle Bow down Bow down CSK Automotive
Post #209004 6th Feb 2013 7:29pm
