Home > In Car Electronics > Focal Speaker Upgrade
Page 3 of 4 <1234>
barbel jim
It should be there somewhere. Chances are its behind the trim thy have removed.
Post #208577 5th Feb 2013 4:58pm
Probably why the stereo flashed error if there was no speaker connected
Post #208578 5th Feb 2013 4:58pm
Likeomg
got the fronts in fine, amp half in, need to connect it to the head unit and battery unit need to get a cable to connect the rear of the head unit to the amp,
the rears, with the covers on the speakers wont fit, the screws are too short because the rear quarters recess around the smaller old speaker anybody else had this ?
thanks again all especially ethanicus
Post #208761 5th Feb 2013 10:43pm
Yes, Either get some longer screws or make / buy a speaker ring to the rear for the screws to bite into. I would go for longer screws though. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_
Post #208853 6th Feb 2013 12:10pm
Likeomg
any ideas where ill get them? the odd course like ones...
for others...
focals don't fit in this recess properly.
Post #208854 6th Feb 2013 12:11pm
barbel jim
Halfords, maplins local ice shop, or make some out of mdf and spray them Thumbs Up
Post #208862 6th Feb 2013 12:26pm
Likeomg
gonna go the longer screws route..
Post #208863 6th Feb 2013 12:29pm
Mud do shallow and deep adaptor rings only about £8 a pair. IIRC 10cm & 13cm. Personally though I think you should be fine with what you have and use longer screws as you say. If the grille overlaps then it doesn't matter it's still flush either way. If the new longer screws don't work drill some new ones.
Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
Post #208972 6th Feb 2013 4:55pm
Likeomg
When it comes to wiring the amp, I have a kenwood kdc bt92, and the alpine 1200 sub, the 'remote on' on the amp connects to? There's 'ant cont / p cont' and 'steering wheel remote input' / 'remote cont' free,
On the wires out the back of the head unit, there's also a blue cable that goes to nowhere (goes into the adapter) but nothing on the cars side...
Have a pic if anybody wants to
Shoot me there email to show them
Exactly what I mean
The 'remote on' has 2 bullet connectors at one end... Looking at the wiring for the head unit, the blue white from the adapter says 'power control' the other blue white spare which is antenna control / power control says 'when using the optional power amplifier... I guess this is the one?
Post #209502 8th Feb 2013 2:46pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Post #209504 8th Feb 2013 3:02pm
ethanicus
2014 Defender 90 Puma 2.2 XS CSW Corris Grey
Hi,
Yes the blue white is the correct wire to use. This will tell the amp to turn on when the head unit is powered up. Just finished fitting my sub so will add some pics shortly.
Cheers,
Jon
Post #209508 8th Feb 2013 3:55pm
Likeomg
Cool, can't wait mine is in, wired up but nothing is happening...
Post #209513 8th Feb 2013 4:10pm
ethanicus
Make sure you enable the subwoofer output on the head unit (if its an option).
Give me a call if you get stuck.
Post #209517 8th Feb 2013 4:25pm
Likeomg
ethanicus (jon) thank you very! much had a lengthy phone call with him, for some reason my car blew 2 fuses on the amp, eventually got it working... difference is amazing. rears still aren't in, think i need a bigger sub to keep up with the focals tho...
Post #209564 8th Feb 2013 6:30pm
ethanicus
No problem, nothing worse than making a recommendation and then it doesn’t work Whistle
Just finished the sub install. It makes so much differnce, not max power load but rounds out the sound of the Focals.
Few images here:
https://www.defender2.net/gallery/thumbnails.php?album=1095
Also added a aux fuse box to support the sub:
https://www.defender2.net/gallery/thumbnails.php?album=1096
Post #210191 10th Feb 2013 4:24pm
Page 3 of 4 <1234>
