Home > Maintenance & Modifications > Wheel Bearing Service?
stevie d
United Kingdom 2003 Defender 90 Td5 SW Alpine White
Hi,
Does anyone service their Defender wheel bearings or just wait until they fail/ get noisy/ wobbly wheels/ loose break pedal etc
I replaced my front bearing circa 3yrs ago with Timkin bearings and new seals. Just wondering if I need to strip and re-grease at some point?
Thanks,
Steve Thumbs Up Defender 90 TD5 Station Wagon
Discovery 3 HSE
BMW 330i Coupe
Post #208341 4th Feb 2013 5:14pm
Welshsurferdude
Wales
Timken are known to last ages.
Id jack up the wheel, check for play and smoothness, if all ok then nothing to worry bout.
if play then replace!
Should know as I change mine frequently but then I do use mine off road all the time in work and outside work!
edited to add but then they arent too expensive so you could do it for peace of mind anyway? 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS
Post #208346 4th Feb 2013 5:38pm
jst
check for play, tighten if they need it for the old style or replace with shorter shim on new style (or convert to old style)
if you run std size tryes they will last a fair while (assuming normal use) 80-100k. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #208360 4th Feb 2013 6:32pm
