![]() | Home > Puma (Tdci) > Clunking noise when slowing down |
| Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897
Check your propshaft UJs and flange joints for slack.
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8485
if its after a longer run could be the handbrake binding, is the drum warm? Cheers
| borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677
Thanks I will, I would not have expected them to be loose after 3000 miles, but I suppose it is a LandRover!!
steve |
Will check that too - thanks Steve |
| willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789
Most likely hand brake, next time try gently lifting hand brake lever a little bit, noise stops = Handbrake. Original Member Pie n Pea Club.
110 HCPU Tipper |
Thanks Willy Steve |
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6043
On my TD5 I got clunk clunk clunk when coming to a stop. It was oil on the drum causing the brake shoes to bind coupled with handbrake adjustment. After fixing the leak and adjusting the shoes all is well. 1999 Defender TD5 110
