![]() | Home > Technical > Wiper park switch question |
| lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006
I have a 98 300 and when my park switch died i took it off and gently split it open and replaced the sprung copper strip with a bit of steel from a frameless picture clip and gently glued id back up. Been fine for 18 months now. Rhubarb and custard let fly with their secret weapon.
| SteveT247 Member Since: 21 Feb 2011 Location: Central Posts: 491
Cheers Lambert, I may crack it open tomorrow.
Be careful though cos there is a little coil spring under the plunger bit that the motor acts on just waiting to escape. Also the moving contact is pretty fine. Open it up and see, if you have not returned the ones you bought they may contain enough parts to rebuild yours. Rhubarb and custard let fly with their secret weapon.
Still got them mate so hopefully should be able to come up with a decent one.
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18033
Airlocker, the symptoms you describe are consistent with the park switch not interrupting the power when the wipers are in the park position. There is a live-with-ignition-on feed to the motor, separate to the stalk-switched feed, to park the wipers for obvious reasons. When the wipers are switched off but are not in the parked position, the ignition-live feed via the park switch powers the motor until the park position is reached. When this happens, the switch is operated mechanically from the motor gearbox and the live is removed from the motor, and the motor terminals (note not the feed side, but the motor side) are shorted together so that the back-EMF from the motor brakes the motor to stop almost instantly (in effect it uses regerative braking).
In your case for some reason the switch is never opening, so that the permanent live feed is never bing removed from the motor. The most likely reason will be that there are dimensional differences in the cam and the pressel on the switch between the different generations of motor. |
Many thanks for the explanation blackwolf. I stripped the Britpart item down last night and couldn't see any difference until I read your post, then noticed the dimensions of the plunger are slightly different. I've used some of the internals from the Britpart item and now the original works. Before I read your post however, I went to a local Mini specialist this morning and picked a switch up from there (same switch) which also works a treat, so now I've got a spare. Many thanks guys.
