![]() | Home > Pictures & Video > Timelapse: Crossmember respray |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 ![]() ![]() ![]() |
Here's a timelapse of todays crossmember respray.
Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
dnorrishill Member Since: 15 Jul 2011 Location: Hampshire Posts: 631 ![]() ![]() ![]() |
Proper job - looks great and once the weather improves is exactly what I plan to do.
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
Excellent job. Great production, you must be well-chuffed!
![]() Treat every day as if it is your last....one day you will be right!! |
Rakthi Member Since: 30 Nov 2012 Location: Where the cats are Posts: 200 ![]() ![]() |
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1135 ![]() ![]() |
Great stuff!
1. What software did you use to make the timelapse ? 2. Which paint did you use to spray the x member? ![]() 1966 S2a 109 aka Betsy |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674 ![]() ![]() ![]() |
very good and surprisingly entertaining DEFENDER 90 TDCI XS,
Thud Member Since: 21 Jul 2012 Location: London Posts: 667 ![]() ![]() ![]() |
That was great. Im sure between frames you striped off that paper stick by the tow plate and didn't just spray over it.
sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455 ![]() ![]() |
Good stuff
![]() DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
VOD80 Member Since: 10 Nov 2011 Location: Toulouse Posts: 17 ![]() ![]() ![]() |
Great video. I've just done the same to mine, but used a wire brush on an anglegrinder! The thing that worries me though is what does the other side of the crossmember look like?
I use Sony Movie Studio Platinum, which is my video editor, but just imported all the still images 1600 of them and they are set to run at one image a frame, video is 30fps, so 30 images every second. The paint and primer are both Plasticote. I didn't bother with etching primer as the surface wasn't too bad. In fact I probably didn't need any primer, but better to be safe than sorry. I also like the fact that Plasticote do a black primer. They where each about £7 in B&Q. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
![]() I did think something similar, but the condition was only very slight surface rust and didn't want to take too much of the original paint off Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
Of course...... ![]() ![]() 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
