![]() | Home > Maintenance & Modifications > Fuel Cooler Guard |
MrFlips Member Since: 27 May 2009 Location: Cardiff Posts: 682 ![]() ![]() ![]() |
If it's a Devon one then I fitted mine in under ten minutes (and I've rarely got a clue what I'm doing), it really is that simple. I take it you've found the instructions at http://www.devon4x4.com/download-document/...tions.html. Follow these and you can't go wrong.
![]() 2008 SWB Truck Cab 1952 80" Soft top |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
It is the very one (my mom bought me that, i find it very cool she managed not only to contact devon, but order the correct one and give it to my wife to give to me for christmas!)
Thanks for the instructions Mike |
That is incredibly impressive of your mother.
Thanks for the tip - been out fitted it and added some waxoyl Mike
markalpha Member Since: 23 Apr 2008 Location: Downham Market Posts: 690 ![]() ![]() ![]() |
Top present mse. Also very useful. I have one and they are very good but I think mine may give a slight metallic vibrating noise on gravel tracks. Has anyone else found this or is it something else rattling.
Not that ive been on any tracks with it yet - but it seems ok...i did wonder how tight to do the bolts back up Mike
Mad Cow Member Since: 27 Oct 2009 Location: Hertfordshire Posts: 292 ![]() ![]() ![]() |
Mine is still sitting in the box, after unwrapping it on Christmas day!
I was wondering how to fit it so this thread has proven useful. Thanks ![]() 2007 90 Hard Top - 2009 BMW F800GS - 2002 CCM 604E Dual Sport Project90 |
Dead easy - 2 bolts, 10mm or 8mm i cant recall - the waxoyl already held the clips in, but i kept and eye on them.
Added some more waxoyl behind (an area i didnt do originally) and on the guard (something i do to anything i fit) and did up - nipped up tight not over tight. Mike |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
why wouldn't you tighten it up fully? There's quite a lot of vibration down there and you wouldn't want it to wobble off. How tight were the bolts when you took the originals out? One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
By tight i mean nipped up...i had a tendancy to overtighten (hang off) things and strip threads...i may check it - but i nipped it up firm
They werent done up too tightly - theres probably a low torque figure somewhere Mike |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 764 ![]() ![]() ![]() |
Hi
This protection is suitable for all versions ? I want to buy one for my new 110CrewCab .... And by the way, do you know if the gearbox protection, also sold by Devon, can also be fitted on 110's ? Thanks Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
I have the cooler guard on my '09 110 Double Cab - it fits perfectly ![]() Bob |
Got mine last night! Going out to fit it later
![]() Also got a transmission guard. Woo hoo One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
Fitted the fuel cooler guard just now (by torchlight in the end). Was paranoid about losing those spring nuts into the chassis but it was fine in the end - there's plenty of room to work with.
The transmission guard was another story, though. I was hanging off the spanner trying to undo the bolts in the transmission case and they wouldn't budge. I couldn't fit a socket set between that and the handbrake drum so will have to figure something else out another day. Come to think of it, LR still have to do the recall fix on the transmission case gasket. I don't know whether that involves removing those bolts but it it does, I'll just give them the D44 ones to put back in so I can just bolt the guard straight on. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
