Home > Td5 > Oil pump bolt loosening? |
stevie d Member Since: 09 Nov 2009 Location: Bishops Stortford Posts: 342 |
I believe it was the early models.
Mines a 2003 and my Indie says it's ok. Steve Defender 90 TD5 Station Wagon Discovery 3 HSE BMW 330i Coupe |
31st Jan 2013 9:28am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6041 |
New bolts come pre-coated with threadlock.
I've got some pictures at home of the old engine I bought that had this happen to it... wasn't a pretty sight (although the engine had been run for some time afterwards, it was totally wrecked.) |
31st Jan 2013 10:10am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16899 |
The problem had been sorted by 2002 when my Disco rolled off the line.
31st Jan 2013 10:14am |
taffrican Member Since: 14 Jan 2011 Location: Living room Posts: 622 |
whew! Optimists say the glass is half full.. Pessimists say the glass is half empty.. Engineers say the glass is twice the size it needs to be! |
31st Jan 2013 5:17pm |
joelyates18 Member Since: 22 Dec 2012 Location: Neath Posts: 39 |
Easy fix is to get your local garage to take the old bolt out and fit a new one with threadlock at your next service!
31st Jan 2013 6:42pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5745 |
An easy fix that needs the sump removing to do the job?
Was there a recall for the early Td5s? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
31st Jan 2013 6:52pm |
Ok so maybe not easy but at least your engine won't blow up
31st Jan 2013 7:13pm |
df1 Member Since: 06 Aug 2011 Location: Ireland Posts: 221 |
So it seems it's been sorted on my 2006 model then?
31st Jan 2013 8:25pm |
Yes, you should be ok. It would have failed by now if it wasn't sorted!
31st Jan 2013 11:33pm |
