Home > Maintenance & Modifications > Home made fridge mounting plinth |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
Are you sure it's strong enough?
Looks underengineered to me |
29th Jan 2013 11:52pm |
TooTall Member Since: 10 Jul 2012 Location: Fens Posts: 504 |
Franticly looks for irony reset button :L "Ease your worries, Clear-up your woes,
Go into your garage & put stuff into rows." |
30th Jan 2013 5:40am |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Did something similar in the old 110 all i'd add is the proper locking floor for the fridge
30th Jan 2013 7:27am |
if you have changed your rear wheel carrier, the part you take off the back door works well as a bracket to bolt to the seat fixings/floor, then add the fridge tray/base. I used 20mm ply as a base for mine and bolted the focal sub to the bottom of the tray and there still room for the first aid kit, paper towels and emergency bag. Because I use a fridge or an icey-tek cold box, I fitted ali locking tracking to the tray / base to strap the units down.
30th Jan 2013 8:18am |
SteveS Member Since: 05 Oct 2010 Location: Devon & Berkshire Posts: 388 |
Irony and taking is fine.
I guess the answer to the question about whether it's strong enough will all play out once I get onto some corrugations in Morocco. I used to work many years ago in a company that had a vibrating bed table to do military testing of equipment and metalwork. When viewed under strobe lighting you'd be surprised just out of shape items can get when the bed hits the right harmonic....often to the point of fracture. |
30th Jan 2013 9:00pm |
tatra805 Member Since: 16 Aug 2011 Location: Dolany Posts: 436 |
why do i have a feeling something else on the car might disintegrate way earlier at any random harmonic before your construction does? |
31st Jan 2013 1:17pm |
Like me for instance I'm not sure how much g and deflection you might expect on a corrugated road (it feels unpleasant) - but the vehicle is the sprung/damped weight but not perfectly so and some of that energy gets through. Even if it were only 2g then my 50kg (full of beer) fridge suddenly becomes 100kg. Then you need to think about shock/impulse. having it strapped firmly to 2 tons of steel obviously helps a lot I'm sure somebody could calculate it for me....pretty please Putting all that aside it really boils down to if you set out to make it out of wood then you need something readily available and able to be built up....ie 100mm x 25mm is harder to bolt together on the thin edge (to make it 200mm) and is more likely to twist Anyway - i'll find out soon - i can always use it for firewood - should keep the fire going for a few days |
31st Jan 2013 8:40pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10367 |
Nice install. It made me look in your gallery for more on your truck, but little seen. I'd like see a full build thread if there is one on another forum?
Looks fab. |
1st Feb 2013 12:33am |
