Home > Technical > Windscreen Washer Jets
x-isle
Been having issues with my front jets for ages, then suddenly, lots of water came out.....
.......forwards.
On inspection, the Jet has come off. I think they've been blocked and the pressure of the water has pushed it off.
So, I've bought a new one as pictured below. Rather than change the whole thing which is a centre console off job by the looks of it, I assume I can also break this one too to fit.
It looks like the assembly pushes onto the end of the threaded pipe, however, am I correct in thinking that it's just bonded in place? To me it looks like a bit of a risk of cracking it splitting it.
Has anyone else done this, or should I stop being a lazy ass and get the centre console out?
 Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #206777 30th Jan 2013 11:50am
ZeDefender
The big nozzle part just pulls off the end of the threaded pipe - not even bonded. There is just a ridge on the end of the threaded pipe.
Lot of resistance though, so "screw your courage to the sticking place" and pull like hell - there's just a solid plastic ridge to overcome and it will pop off Thumbs Up Tell someone you love them today because life is short.
Post #206791 30th Jan 2013 12:58pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
I did the same, bonded the new one on so it shouldnt come off again!
Pete.
Post #206792 30th Jan 2013 1:00pm
x-isle
Cheers Thumbs Up Thumbs Up I can go back to being a lazy git..... That heater dial bulb still won't get replaced...... Rolling with laughter Craig Rogers
2007 Puma 110 XS
Post #206793 30th Jan 2013 1:00pm
mine always used to pop off when it was frosty (obviously not enough anti freeze in the washer water)
Once they "come off" they tend to come off more easily, so a dab of superglue when you re-fit should stop that happening again.
Post #206803 30th Jan 2013 1:54pm
x-isle
Thumbs Up Craig Rogers
2007 Puma 110 XS
Post #206808 30th Jan 2013 2:07pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Yeah mine came off the same as well, it was clearly not glued at all.
Problem was the replacement I purchased was glued, so tough time separating the nozzle (but I eventually managed to take it off).
But I wasn't so pleased with that solution, it was no better than the original which failed eventually.
I eventually replaced the entire assembly with (another) one which was glued from new. It's not that hard, remove the radio, the central dash, remove the metallic bit that holds the back of the radio and you can access the nut and undo it from behind the dash.
Not that hard, really, took me an hour or so. I took the opportunity to inject a fair amount of clear Waxoil behind the dash and in the bulkhead through the hole, while I was at it...
Post #206811 30th Jan 2013 2:25pm
ZeDefender
Didn't realise its that easy to get to from behind the radio - might further improve my wash/wiper system when I tidy up my cables Thumbs Up Tell someone you love them today because life is short.
Post #206822 30th Jan 2013 3:09pm
^^^^ That's just what I did.... I bought 2 new jets, a "T" piece and some hose. when mine failed last time I whipped the dash top off and fitted 2 jets, one either side (used the LHD wiper arm holes)
Trouble is, my washer pump motor is a bit weak, so need to get another/better one for some more pressure Rolling Eyes
Post #206827 30th Jan 2013 3:32pm
ZeDefender
My "T" is on the outside for now, held onto the washer stub with a small hose clip - looks okay (works brilliantly) but inside the dash will be tidier Thumbs Up Tell someone you love them today because life is short.
Post #206828 30th Jan 2013 3:49pm
x-isle
Cheers all. New one was glued together, a lever from a screwdriver later and I was left with it split. Put some hot glue from a glue gun on the existing pipe and all is good again.
I can actually see where I'm going again! Craig Rogers
2007 Puma 110 XS
Post #206901 30th Jan 2013 8:23pm
ZeDefender
That's a Censored Sad
If you do need to get at the washer assembly from inside, centre dash removal is here:
http://www.defender2.net/forum/topic16968....ck+removal
Post #206916 30th Jan 2013 9:02pm
x-isle
Just in case, by split, I meant split as in 2 parts, not split as in broken! Thumbs Up Craig Rogers
2007 Puma 110 XS
Post #206946 30th Jan 2013 9:56pm
ZeDefender
Aaahh Thumbs Up Thumbs Up Thumbs Up Tell someone you love them today because life is short.
Post #206974 30th Jan 2013 10:59pm
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
Could someone supply me with the part number please for the washer nozzle as mine has gone walkies, cheers in advance
Paul Thumbs Up Cogito ergo sum
Post #632464 20th Jun 2017 4:09pm
