Home > Td5 > TD5 temperature gauge fluctuating
Page 3 of 5 <12345>
excossack
I'm with you now. The next question is.... What makes the gauge go to zero ? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #206870 30th Jan 2013 6:41pm
Laurie
Just before it goes to the red it sometimes fluctuates rapidly which may lead to it going to zero.
Driving ar 60mph with a caravan on the back is hardly the time to closely monitor the gauge! Rolling Eyes
Post #206874 30th Jan 2013 6:55pm
excossack
Added an extra earth from the earth stud in the seatbox to the screw/bolt holding the ECU in place. And then I ran another earth from the earth stud to an earth block I have for additional wiring which is earthed to the 2nd battery and this battery is earthed to the main battery...So I think that's a good earth.
Next thing I am thinking of is an earth from the chassis(where the earth from the battery comes outs and mounts) to the engine block. Is there a good earth point on the block or will anywhere do ? 1999 Defender TD5 110
Regards
John M0VAZ
Post #207091 31st Jan 2013 3:33pm
excossack
I have done another earth connection, this time from the white earth connection from behind the coolant expansion tank to the earth stud in the drivers seat box.
Time will tell. 1999 Defender TD5 110
Regards
John M0VAZ
Post #207315 1st Feb 2013 1:29pm
excossack
Well after doing the additional earth connections. During a 40 mile trip up some A & B roads the gauge was OK.
On the trip back down the motorway the gauge did its normal trick of dropping to the off position and then after stopping and starting the engine it returned to normal for a few miles then started fluctuating again...
Back to it checking wiring. I think I have spare temp sensor that came from a FPR. So I might try swapping the sensor out. 1999 Defender TD5 110
Regards
John M0VAZ
Post #208084 3rd Feb 2013 7:55pm
stuckinmud
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Bonatti Grey
sorry my previous post incorrectly referred to fuel pump relay but looking back at td5 haynes manual the fuel pump relay is the third non yellow relay in the area under drivers seat.
the two yellow relays are referred to as the main relay and heater plugs relay.
it was one of these two yellow relays which had gone bad but was fairly easy to diagnose by swapping the two yellow relays over until i could purchase a new one.
gauge flickering disappeared instantly
Post #209998 9th Feb 2013 11:27pm
excossack
Interesting as my fuel pump relay appears to be in the fuse panel section behind the gear stick.
I will have another look tomorrow.
Can these relays be swapped with standard relays? or are they specific to LR? 1999 Defender TD5 110
Regards
John M0VAZ
Post #210024 10th Feb 2013 12:16am
Laurie
I tried Halfords relays and they didn't work.
Post #210032 10th Feb 2013 12:44am
stuckinmud
in my td5 they were ford relays which i sourced from my local car parts suppier via the part number on the relay. have a look under the drivers seat for the two yellow relays. it was one of these causing the problem and swapping them over caused the problem to disappear. i then took the cover off the faulty relay to find the contacts were burnt confirming the problem.
Post #210040 10th Feb 2013 1:37am
excossack
Now its not raining or snowing, I had a look at the car. Replaced the coolant temp sensor with one from a Fuel Pressure Reg and checked the wiring. From what I could tell all was OK.
Had a look under the drivers seat and I have two relays.
Yellow and Black. The yellow looks like a standard relay, but the black looks standard but has bigger terminals that plug into the relay socket.
With both of these relays unlplugged the glow plug warning light didn't illuminate and the car cranked but would'nt started.
So will keep an eye on the needle and see what happens. 1999 Defender TD5 110
Regards
John M0VAZ
Post #211674 16th Feb 2013 3:44pm
238kirk
United Kingdom 2003 Defender 90 Td5 SW Belize Green
Any joy with this problem? I went on a run today and my temp gauge was flicking abit and would drop off to the bottom as though it wasn't working, also it was a real pain to start from warm, when it was turning over it was almost starting but just not quite and the gauge was jumping around too, just wondering if my problem could be similar to yours Neutral
Post #213834 24th Feb 2013 5:00pm
excossack
I think its too early to say, but at the mo the temp gauge is behaving itself after changing the temp sensor. I am due a good run soon (going from near Liverpool to Blyton, North Lincs) so that will be a good test.
Not sure on the starting. Mine used to play up starting from warm or not starting at all just clicking and that turned out to be the starter motor. But the temp gauge didn't bounce around while cranking 1999 Defender TD5 110
Regards
John M0VAZ
Post #213861 24th Feb 2013 5:52pm
excossack
Well after a 300 mile round trip on the M6 and A66 the temp gauge did not flicker at all Smile
To achieve this, I put it down to swapping out the coolant temp sensor.....and the car feels quicker as well
Would swapping out the coolant temp sensor make the car feel quicker? 1999 Defender TD5 110
Regards
John M0VAZ
Post #215638 2nd Mar 2013 9:59pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
Something someone said to me implied that it could. If the engine is not getting up to temperature (or at least ECU thinks it is not) it doesn't give you full power. I'm not certain on this but sounds sensible.
Post #215643 2nd Mar 2013 10:07pm
excossack
If its anything like my old Lada Niva 1700i, the coolant temp sensor went faulty and the car over fuelled and caused fuel consumption to increase. 1999 Defender TD5 110
Regards
John M0VAZ
Post #215646 2nd Mar 2013 10:10pm
Page 3 of 5 <12345>
