![]() | Home > Puma (Tdci) > Help Please - ? Broken Solenoid |
hi Kris
I'd start by checking all the relays are seated properly and dry what sort of temperatures are you in at the moment, how about warming the start up with a blow torch ? |
Phoenix90 Member Since: 04 Mar 2012 Location: Cornwall Posts: 377 ![]() ![]() ![]() |
Hi Steve,
All relevant relays cleaned, and re-seated but were working as they should prior to cleaning them. Temp is only about -5 at the moment and this began on the ferry when temp was still in the plus (+4ish...) but will give it a go. ![]() |
do you have the wiring diagram ... do you need a copy ?
Alternatively, does anyone know the ford part no. for this alternator? There are a lot more Ford dealers than LR here!
Delskinz Member Since: 18 May 2012 Location: North Devon Posts: 84 ![]() ![]() ![]() |
Phoenix, if you can't hear the click from the solenoid it's probably just stuck. Get a suitable length of wood someone to turn the ignition switch and give the solenoid a good tap. As your on the road at the moment taking the solenoid out and greasing it isn't an option.
Thanks Delskinz, i'll go give it a try in a minute, though it is bloody freezing out there now!
Kris
LR part numbers... alternator is YLE500310 (is also ford number) ; starter is LR010547 have a look at this link for the starter ... seems they are for ford, LR, citroen etc... http://www.q11-shop.de/k/teile/bosch-anlas...0090-79244 part numbers listed at the bottom of the page good luck |
did the starter get wet ? is the inside frozen ?? WD or lithium grease may help
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8396 ![]() ![]() ![]() |
did the tapping work, sounds like a sticking solenoid. Cheers
I once experienced that, though there seemed to be a 12V supply on the relay on the starter motor, there was some resistance in the supply wire to this relay. As a temporary "repair" I installed another relay in between, so the original relay on the starter motor got a new supply now directly from the battery via a new thick cable. The helping relay is activated by the original supply wire. This wire had enough current for activating the helping relay, but not for activating the original starter motor relay.
Sounds a bit fuzzy, but hope you understand what I mean ... ![]() 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Thanks for all the suggestions guys.
In the end I took all the cables off (what a ![]() I think the Solenoid o/p cable nut was loose when I took it off which may explain the issue! Fingers crossed for the rest of the trip! ![]() |
great news Kris.
how are the snow tyres performing ? have you fitted your studs yet ? seen the lights ? |
You have PM
so do you
