![]() | Home > In Car Electronics > £7.99 Aerial upgrade. |
| XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632
Cool! I assume the threaded piece you crimped on is a good tight fit, or it could part company at speed.
Pete |
| SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527
Sweet
| GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555
Nice! Can't go wrong for £7.99
"Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
| Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265
* It's a Land Rover, if at least one part doesn't fall off per journey then it's not working as it should. *Yes, it's very tight, hence the ratchet crimpers |
Day light photo, I'm quite chuffed with this. It looks okay I think.
Click image to enlarge Last edited by Tiger on 13th Sep 2013 11:07pm. Edited 1 time in total |
| x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327
Awesome, I love a good bodgejob!
I might give this a go on the weekend as mine works ok, but it doesn't go all the way down and get's stuck. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
Tiger!.....
Just did mine the same. I opted for a VW replacement for £3.85 http://www.ebay.co.uk/itm/270955002855?ssP...1497.l2649 Works a treat! Perfect reception! Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
| Norm4n Member Since: 31 Aug 2012 Location: Surrey Posts: 329
Is that a straight replacement or is some jiggery pokery required? |
£3.85 ! - you win
It really is simple. As Tiger explained, cut/snap the original off at the last section then screw the threaded bar into the remaining aerial left over. Crimp it with cutters/pliers/crimp tool and screw the new aerial in. Push down flush. To be honest, the thread took so well inside the original aerial that it didn't need to the crimped but did it anyway. Checked the radio and FM, MW and LW all work perfect. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
| Thud Member Since: 21 Jul 2012 Location: London Posts: 667
That looks a bit Heath Robinson to me. You lot are a load of cheapskates.
Yorkshire and proud
Welsh and proud Craig Rogers
