![]() | Home > Puma (Tdci) > Mud flap mounting |
After reading so much about this before picking mine up, i thought I'd check out how good they looked straight out of the factory:
![]() Click image to enlarge can't see this staying on long ![]() Not sure if I should be pulling the wing in before nipping up the bolt or put a couple of spacers underneath the inner fitting to space the whole arm out: ![]() Click image to enlarge I know I could take it back to the dealer but I think I'm going to put a couple of pieces of ali right angle in as well to strengthen both the inner and outer mountings (there's already a hole through the arm for the inner fixing. having done that - I know where the mudflaps will fail - right across the rubber immediately below the rivets at the point they flex under use ![]() |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472 ![]() ![]() ![]() |
The powder coating will fail in no time too! Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
We still have the Entreq reinforcing brackets in stock
![]() We also now have rear 110 mudflap brackets available in stainless steel and powder coated stainless. Not Entreq unfortunately. Brendan |
