Home > Maintenance & Modifications > Fitting heated mirrors
ibexman
Can i use the heated rear screen switch for heated mirrors as i never use it Thumbs Up
Post #205876 27th Jan 2013 1:09pm
TD5_dan
2001 Defender 110 Td5 CSW Java Black
Just wire it to do both everything has relays so that will be fine 2001 TD5 110 County Station Wagon - sold
1970 Series 2A Station Wagon
1970 Series 2A hard top
1960 Series 2
1972 Series 3
Post #205887 27th Jan 2013 1:19pm
ibexman
How do you do that?..
Post #205898 27th Jan 2013 1:51pm
K9F
Carefully...... Rolling with laughter
Using the same principle as the spotlight diagram below. Whereas the light switch is obviously your heated windscreen/rear window and the lights are the mirrors. Using the Puma Diagrams you should be able to tap into the heated screen loom for your supply to the mirror elements.
If you've an XS model with front heated screen.....
Front screen relay R208 purple output cable contact C0994-87
Or if not.....
Rear screen relay R138 output cable contact C0044-30
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #205903 27th Jan 2013 2:00pm
SGH
I was going to wire my heated mirror to the heated screen so they come on when screen is on.
Post #206077 27th Jan 2013 10:42pm
JWL
To buck the trend I wired mine up independently as I don't use the rear screen very often but find that switching them on helps when they mist up due to spray on motorways and major roads. It's all manual at the moment and one of these days I'll put a timer in the circuit to help me from having to keep checking if the tell tale is on.
Post #206103 27th Jan 2013 11:34pm
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
That's exactly what I did with mine, the current draw is so little it won't make much difference. Works just fine Thumbs Up Optimists say the glass is half full..
Pessimists say the glass is half empty..
Engineers say the glass is twice the size it needs to be!
Post #206155 28th Jan 2013 2:41am
