Home > Puma (Tdci) > Fitting a winch?
stevie
Fitting a winch?
I now need a winch on the front of my double cab. Just want to make sure I get it right so any advice would be appreciated.
What as was thinking is a warn 9.5 cti, Mantec bumper, and a front mounted tow ball on the bumper. I need the tow ball on the front as I ll want to hitch a trailer upto the front of the landy and winch things up onto the trailer.
I don't want a fancy front bumper as I want it to look fairly standard.
So,
Warn 9.5 cti
Appropriate wiring to get to the battery
Mantec bumper
Tow ball
Have I missed anything?
What's thought on front springs? Do they need uprating? Land rover say not ,1 Indy say no and another Indy says yes.
Post #205533 26th Jan 2013 3:47pm
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
I don't know too much about winches, but as you are fitting a front towball, how about one of the removable ones mounted on a tray?
That way you could use front or rear (or swap between vehicles) as long as you have an Anderson connector each end, which is always useful for jump leads.
So no worries about uprated springs as most of time It'll be in the back.
David Bowyer has a couple of tray options which will fit quite a few different power winches, may even be able to fit a Warn on one as well.
Certainly worth considering, had a goos chat at a show about them, seems like a nice chap as well.
Dj 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #205539 26th Jan 2013 4:16pm
Defender-Stu
I would say yes to the front springs as need to take into account for the extra weight on the front, the best people i would deal with is Devon 4x4 as they would sell you the right springs forthe weight Thumbs Up
Post #205542 26th Jan 2013 4:20pm
stevie
Thought about the tray mounted ones. Would be handy as when you get stuck you often could do with a rear winch! I ve looked at them on the warn website and the picture of the bloke lifting one onto the back of his truck made me think it could be a bit heavy to be lifting on and off. I couldn't keep in the back of the landy as this is full most of the time and I have a trailer on a lot of the time, so couldn't stay on the back. The ease of theft was an issue too.
Post #205547 26th Jan 2013 4:35pm
Dieselhead
I have a Warn XD9000I c/w Mantec winch bumper on mine
All fitted by Landrover when new at a cost of �1534.47 plus VAT
Its only ever been used once by its 1st owner. I have yet to try it Razz
Front springs are standard Thumbs Up Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #205580 26th Jan 2013 6:32pm
BigMike
duplicate
Post #205587 26th Jan 2013 6:54pm
BigMike
I would not fit a winch without heavier rated springs. Iron Man are ideal, not to mention cheap. Goodwinch TDS Goldfish has never let me down and has been used a LOT. I have a goodwinch bumper specially for puma aircon models I could sell to you for 250 and is brand new.
Post #205588 26th Jan 2013 6:55pm
BigMike
duplicate
Post #205590 26th Jan 2013 6:55pm
bob neville
I've got a Superwinch Talon 9.5 with synthetic rope and TF tubular bumper on my DC. Both items are ****** heavy. Front end must have dropped all of one cm, probably more like .5cm.
Wait until you have fitted everything before upgrading the springs, I doubt you will need to upgrade. If you do I have a pair of 1" lift front springs for a 110 that I have never needed to fit.
This is how it looks, bog standard springs.
2013 Defender 90 CSW - sold
Post #205595 26th Jan 2013 7:00pm
You won't need to change the front springs.
The only item I would add is a heavy duty battery switch in the winch cable that you can easily isolate
Post #205596 26th Jan 2013 7:08pm
v40mav
I'd also say that you should be okay on standard springs unless they are already tired and needing replaced.
To save a few pounds go with a plasma rope and alloy / stainless fairlead
I've a T-Max winch on with Mantec bumper. Some pics in my gallery - I recently changed to plasma - what a difference - but it will depend on what you use it for -
[/img] Defender 110 County SW
Disco 3 HSE
Freelander 2 HSE - SOLD going back to a car
www.lothian4x4response.org
Post #205597 26th Jan 2013 7:10pm
jst
are you using it for vehicle recovery or for winching things onto a trailer?
if the latter a Warn 9.5 is overkill and i would trailer mount it powered from anderson sockets of the tow vehicle
if you want a demountable system i still have a Cl2(?) receiver hithc cradle and front def fitment (possibly rear too ) for sale.
my recommendation would be a new TDS at the �500 ish mark over a Warn for greenlane/occassional recovery use. if your into heavy winch use then a Warn could be justified. But generally they are expensive, no more reliable than any thing else, have expensive parts and does the 9.5 not have a cone brake in the drum? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #205612 26th Jan 2013 7:32pm
chadjizz
England 2013 Defender 130 Puma 2.2 HCPU Orkney Grey
i am also thinking about getting a winch. just to chuck another question in the mix.... whats the max power winch you could run.... i have a 130 and tow trailer loads of fencing into feilds, so if i get stuck i could be winching min 3.5ton. im thinking a superwinch talon 18000lb (8ton) (http://www.ebay.co.uk/itm/120915766659?ssP...1423.l2649) or is that just going to rip the front bumper off!!!!!
Post #205631 26th Jan 2013 8:02pm
speedymarktd6
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Epsom Green
I would go for a milemarker hyd of the power steering on a 130 there wouldnt be a lot in it price wise
Post #205779 27th Jan 2013 12:17am
Alternatively use a snatch block to effectively halve the load on the winch (although halve the speed as well) and get a smaller 8 / 9000lb version
Post #205812 27th Jan 2013 9:25am
