![]() | Home > Puma (Tdci) > EGR again.. (I think) |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Might be this http://www.defender2.net/forum/post123953.html#123953
domcoutts Member Since: 08 Dec 2011 Location: Kent Posts: 111 ![]() ![]() ![]() |
Hi Mick,
Thanks for the link.. Mine doesn't seem to clatter though, this evening when it was the worst it's been, when I eventually got going it seemed to make a bit of a whistling noise.. A bit like a turbo. But that stopped when it had sufficiently warmed up. |
Apynala Member Since: 17 Oct 2009 Location: Morroco Posts: 88 ![]() ![]() ![]() |
Hello,
It's exactly what happened to mine this winter. You have to take it off and put some oil into pinions. Now, it works. Bye |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20998 ![]() ![]() |
If your a contortionist then you'll have no trouble. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
![]() ... and less injuries. I've left some skin on metal parts of the engine when I removed mine. ![]() |
Likewise.
Thanks Apynala, at least it confirms my suspicions. It was a devil of a job removing the plug (got big hands with short stubby fingers) so dreading the job of removing it.
There's no way the cover could be removed in situ and give it a spray of WD40?? ![]() |
I think it's not possible. Sorry! |
Wishful thinking then, ho hum ![]() |
SGoggin Member Since: 04 Jul 2009 Location: Australia Posts: 19 ![]() |
I reckon you could drill a very small hole in the plastic cover and use some spray chain lube to inject some grease. And then not have to remove the EGR valve. I've got an old EGR valve sittign here that I've pulled apart and I reckon you could easily do this if you get the right spot.
Bear in mind there is a new version and old version of the EGR for th 2.4 and they both do the same job but are slightly different. (casing) ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 ![]() |
I changed an EGR valve on a mates puma today.
Took under an hour. 2 x 8mm head bolts on the bottom & 2 x 10mm bolts for the side Found the best way is 1/4 drive sockets with lots of extensions Best way to get to the lower 10mm bolt is to lay under the truck & reach up I held the lower metal gasket in place with some grease ![]() I did have some skin left on my hands when I had finished ![]() 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
I did that. Damned tight though. You wait until the aches kick in now. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
