![]() | Home > Puma (Tdci) > Alarm LED in dash flashing whilst driving |
| borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677
Will try that tomorrow.
Steve |
| WWA Member Since: 12 Aug 2012 Location: Northumberland Posts: 197
I shall also try that
Didnt come on at all, but driving tonight the light flashed once over a 120 mile journey, so it really is random.
Steve |
| AdvTim Member Since: 04 Dec 2012 Location: Kent Posts: 22
I can go a whole journey with it not flashing or flashing once if I have the radio on and the phone not plugged into the lighter socket. As soon as I do plug the phone in I get a double flash then it might behave for as much as 30 minutes before the light show begins |
| chadjizz Member Since: 25 Apr 2012 Location: sussex Posts: 559
mine is one long flash (1 or 2 seconds long) and it only is once in a blue moon.
| SGoggin Member Since: 04 Jul 2009 Location: Australia Posts: 19 |
Mine started doing this - and I can now reproduce the random flashing. It seems to occur only in the underground car park at the local shopping center - so I reckon it must be picking up some external interference from either another vehicle, or perhaps in the shopping center itself.
mine is the same, it does it everytime i go past a certain point on a local road to me, the slower i am going the more (3 max) flashes i get...! |
| tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279
Same on mine. Randomly, alhthough, somehow I get the idea if it lights up for a second, it's usually when I'm slowing down for the slow corners.
Can't imagine the battery will be low as I have the car for less than 2 months. |
Hey Landrover, if you are monitoring the sites please look into this. Something must be causing it!
| sweepc Member Since: 19 Jun 2011 Location: uk Posts: 568
Mine also does totally randomly and generally flashes very quick but tonight it stays lit for a few seconds. Has anybody made any progress finding a cause?
| Cakey Member Since: 19 Feb 2013 Location: Cheshire Posts: 468
Mine does the same my13
Swapped fob battery seems ok |
[quote="Cakey"]Mine does the same my13
Swapped fob battery seems ok[/quote] Thanks Cakey ill swap the battery tomorrow and see how it goes! |
The Defender will be off to the dealer coming Monday to get a part changed. Haven't asked what it was, but I'll let you know if they get this problem solved.
Have to say, I didn't really mind the light flashing once in a while, but as the Defender is under warranty, I might as well get it fixed. |
| Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630
Mine did this the other day too.. One long flash (around one second).. Just long enough for you to go "what was that?"... Mine is also a 2.2 13my Defender. It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
