Home > In Car Electronics > Radio Comms
x-isle
Radio Comms
Sort of on topic, sort of off, but does include my Landy, so bunged in here.
With the biking holidays that I run, the Landy is the support vehicle which can be up to around 12 miles away (in a straight line).
Currently, I just use PMR446 radios (the awesome Binatone Action 950).
I carry one and the other is in the Landy with support driver. Pretty impressed by the range of these things, managed to get about 5 miles in the hilly mid-wales.
However, I'm also looking at improving this. So I have options....
1) Just stick with PMR446
2) Go for the licensed VHF 5 Watt Handhelds
3) Go for a Landy CB unit with a Handheld CB
My own thoughts on these option is as follows;
1) Cheap, licence free, works "ok", however, if it's inside the Landy, then range is drastically reduced.
2) Licence fee (although cheap at £75 for 5 years), can also get external antenna for the Landy
3) Full on CB (Roger, Roger, 10-4) for other uses, external antenna, powerful.
However, the caveat on option 3 is that it's my understanding that handheld PMRs can have a better unit to unit range than a CB to Handheld CB range??????
Thoughts anyone? Very Happy Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #204943 24th Jan 2013 12:59pm
JWL
No matter what you use if you're in hilly areas then you are compromised, even the day to day communication device we all carry now can be useless.......the mobile phone. personally I'd stick to what you've got, phone as a backup and try to have timed rendezvous points along the route.
Post #204950 24th Jan 2013 1:30pm
x-isle
Yes, we have checkpoints during the day which are variable in length, but never more than around 10 miles away.
The evacuation/abort plan in place is that if we need the Landy in a hurry, a point on the map is decided to where the Landy can reach and we communicate the co-ords over the air.
As you say, being in Mid Wales is not the best, mobiles are pretty useless which is why we have to use radios as we generally get no signal on mobiles. Craig Rogers
2007 Puma 110 XS
Post #204954 24th Jan 2013 1:34pm
YeomanOfTheBar
United Kingdom 2013 Defender 110 Puma 2.2 DCPU Santorini Black
JWL is right about the hills being the major limiting factor - the only (portable) way to really guarantee comms in that sort of environment is sat phone. But that's a $$$ option... 2013 Defender 110 XS DCPU
Post #204981 24th Jan 2013 4:07pm
x-isle
As you say, Cha-ching.....and then there's the need for 2... Shocked
There is always smoke signals! Smile Craig Rogers
2007 Puma 110 XS
Post #204986 24th Jan 2013 4:30pm
YeomanOfTheBar
True. Could always look at renting a pair for the duration of your trips... 2013 Defender 110 XS DCPU
Post #204988 24th Jan 2013 4:36pm
x-isle
Thumbs Up Not a bad option and not that expensive either. Craig Rogers
2007 Puma 110 XS
Post #204991 24th Jan 2013 4:40pm
excossack
For the bike events I do we have a radio controller with mast up and most of the cars have radios and use mag mounts or body mount aerials . We use a High Band frequency which I think is on UK General frequency.
When one radio car can't make it to the controller we relay through another car that can make the trip. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #205042 24th Jan 2013 8:28pm
x-isle
Sounds pretty awesome,but a bit overkill for a holiday with 8 riders all in one group.
Thanks for the rental Sat tip though. That seems pretty perfect. We only need devices to be used in rare circumstances so little to no cost. Craig Rogers
2007 Puma 110 XS
Post #205049 24th Jan 2013 8:38pm
littlepow
I don't think you can get much more out of the PMR446 as it is restricted to internal aerial and a max power of 500mW. If I knew what I was doing - I would be scared!
Post #205067 24th Jan 2013 9:09pm
Tiger
Sounds like you have a pretty good solution already, why not back it up with a SPOT carried by the guide.
That gives you a 3rd option if both radio & cell are not working. Also nice to have if you got stuck up Darkest Wales with no signal and somebody falls.
Would also allow support vehicle to track progress. Great bit of kit.
Post #205068 24th Jan 2013 9:11pm
x-isle
SPOTs are great bits of kit. I've considered one before. Craig Rogers
2007 Puma 110 XS
Post #206049 27th Jan 2013 9:51pm
