Home > In Car Electronics > Pioneer DEH-4500BT
xatzhs
Pioneer DEH-4500BT
Just nipped down to my local car audio shop up here in Newcastle, and had a chat to one of the guys there. Following that, and what I need/want, this seems to be a good option
Pioneer DEH-4500BT
It is being sold for £109
Has anyone had any experience with this or think I should keep looking?
All I want is a head unit that can do everything the LR one can do but with iPhone compatibility and a microphone somewhere.
Post #204940 24th Jan 2013 12:51pm
From your link:
"Pristine sound delivered at 4 x 50W of pure, proven MOSFET power."
You won't be disappointed with that. My HU has the same power rating and MOSFET in-built amp. Thumbs Up
Sadly not from me but perhaps another member on here may have? But for the price and features you can't go wrong IMO.
It can do that no problem. I would check that it has an external mic though and not in-built. Other than that go for it. Thumbs Up ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #204944 24th Jan 2013 1:02pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
They've just added a new DAB unit DEV-6500DAB that you may be interested in. Has iPhone support and Parrot BT too. Seems to be available for ~£120, but you'd need to factor cost of DAB aerial too.
Steve
Post #204949 24th Jan 2013 1:26pm
xatzhs
DAB aerial... where can I get one from? And is it worth it over the original radio type I have now?
Thanks for the advice guys so far!
Post #204958 24th Jan 2013 1:48pm
DAB Aerials are available by either the manufacturer though outlet stores on-line or high-street. There are also some universal one's but personally I'd stick to one recommended for use with the HU make and model. DAB is good for people that like radio / use the radio a lot of which I don't but if you do that would be the advantage of having a DAB HU.
Thumbs Up
I would recommend another manufacturer for DAB Head Unit's but it's best not to. I may get accused of something. Whistle
Feel free to drop me a PM if you would like any other help or info. Thumbs Up ____\We|Will|Win/___
Post #204968 24th Jan 2013 2:18pm
SteveG
All national radio stations will switch over to digital and analogue will just be used for local radio. No date set yet, but old be as early 2015 IIRC
So if you plan to keep radio for a while it pays to buy DAB now.
Steve
Post #204972 24th Jan 2013 2:51pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
just installed a Kenwood DAB 4551...with their recommended aerial
http://www.kenwood-electronics.co.uk/produ...ivers/dab/ BM52
Post #204980 24th Jan 2013 4:06pm
xatzhs
So I embarked on my first ever electrical mod (I know it wasn't that complicated but I was proud of myself!!) and the one thing I have noticed was the nipple like bit at the back which pairs up with the socket and I would suppose keeps the head unit stable on rough roads.
I can't see anywhere to fit it on the new HU... does anyone have any ideas on how to fit it to this HU or any other ones?
I have absolutely no idea what I would search for on this (I presume searching 'nipple' would come up with some rather different results...) so forgive me if it's been covered!
Post #206121 27th Jan 2013 11:53pm
You mean the rubber mounting bung to take the weight of the HU to the rear to avoid stress on the fascia from movement. What bung are you trying to use the one off the OE LR radio or one that came with the new HU? ____\We|Will|Win/___
Post #206125 27th Jan 2013 11:59pm
xatzhs
Pretty sure the new one didn't come with a rubber bung. Was trying to use the OEM one... Is there a way around this? I also can't find a place to screw one in in the same place...
Post #206188 28th Jan 2013 10:51am
TD5_dan
2001 Defender 110 Td5 CSW Java Black
How strange brought that exact stereo from halfords at the weekend! Haven't fitted it yet but has everything I want for the money! 2001 TD5 110 County Station Wagon - sold
1970 Series 2A Station Wagon
1970 Series 2A hard top
1960 Series 2
1972 Series 3
Post #206192 28th Jan 2013 11:03am
I had the same issue with mine too although there was a location on mine to mount the screw on the LR radio was larger so I removed it from the rubber mount and made it fit using a smaller screw and nut. If the HU is pretty lightweight and you already have a DIN mounting sleeve that should be enough support as is. ____\We|Will|Win/___
Post #206194 28th Jan 2013 11:08am
xatzhs
What is a DIN mounting sleeve?
Post #206213 28th Jan 2013 12:02pm
A single DIN mounting sleeve is one of these:
That is mine and it locks the HU in securely for security and to keep the in place. You'd need two removal keys too for when removing your HU out of it as it locks it into place. They don't cost much and if you don't currently have one you really should. Thumbs Up ____\We|Will|Win/___
Post #206215 28th Jan 2013 12:15pm
xatzhs
Oh right, yeh it's got one of those - was a very tight fit!!
So you're saying that with that it should be fine without the rubber plug at the back?
Post #206220 28th Jan 2013 12:54pm
