Home > Puma (Tdci) > whats this creamy stuff
Caterham
the breather off the head / rocker cover has evidence of some kind of creamy stuff?
I was really worried until I had a look in the via the oil filler cap and all looks lovely and clean so I presume there's nothing to be worried about.....
or should I be.....please say no I'm worrying about too many other things at the moment.
Very Happy
Post #204479 22nd Jan 2013 9:52pm
Norm4n
Oil + water = creamy stuff usually
Post #204482 22nd Jan 2013 9:55pm
Caterham
exactly which would have me concerned but I can't see any evidence of it in the head area?
I guess its one of those ......monitor it and make sure it doesn't get any worse.
Question
Post #204484 22nd Jan 2013 9:59pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Perfectly normal, its just condensation/oil residue .... i see it day in day out on Transit Pumas Smile Guns and Landrovers .... anything else is irrelevant.
Post #204487 22nd Jan 2013 10:03pm
Norm4n
I'm sure an intellect will be along soon to explain why, I had it on an old escort once when the breather was blocked or something like that Laughing
Post #204488 22nd Jan 2013 10:04pm
jasong4110
United Kingdom 2003 Defender 110 Td5 G4 LE Java Black
Emulsified Oil on the breather is just a sign that you haven't cleaned it in a while, it is caused when the oil vapour mixes with moist air, noting to worry about as long as there is not tons of it!! If you are worried you can get a "snif test kit" to check for HC in your coolent.
Jason.
Post #204511 22nd Jan 2013 10:41pm
Caterham
thanks Jason..... Shocked haven't cleaned what exactly.
I like things nice and clean so if I missed something I'd like to know...
joking aside what exactly are we suggesting isn't clean - the oil, the breather (do people clean the breather pipe?) ?
thanks
Post #204815 23rd Jan 2013 10:34pm
Dave-H
As i already said .. its normal Rolling Eyes
It's not that you havent cleaned anything .... you just need to wipe it off whenever you check and see it is building up. Guns and Landrovers .... anything else is irrelevant.
Post #204817 23rd Jan 2013 10:46pm
jasong4110
thanks
Not cleaned, just wiped the old stuff off the breather cap, ever once in a while I remove the breather and clean with degreaser. Although as I say it's only oil vapour and water vapour mixing, and nothing to worry about.
Jason.
Post #204819 23rd Jan 2013 10:48pm
T1G UP
thanks
Not cleaned, just wiped the old stuff off the breather cap, ever once in a while I remove the breather and clean with depressant. Although as I say it's only oil vapour and water vapour mixing, and nothing to worry about.
Jason.
jason, thats a td5 thing...nobody else bothers Thumbs Up
Post #204821 23rd Jan 2013 11:06pm
Caterham
thanks.....
.......and relax.
Very Happy
Post #204873 24th Jan 2013 9:30am
Happyoldgit
If you go looking for problems the pesky Defender gremlins will usually make sure you find something Wink Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #204884 24th Jan 2013 10:03am
Caterham
well thats one less thing to worry about....
I went and done it......looking for gremlins !
underside seems to be releasing oil again from the transfer box area !
already had a new input shaft followed by a return visit 4 weeks later for new seals !!
cant be sure so I've had a clean up and will review to see how quickly (if at all) all the oil returns.
Post #206083 27th Jan 2013 10:59pm
i Guess you have used a genuine air filter and the cover is on properly ?
if you look at what the pipe does, it makes sense you may get some oil/water residue, on the one side you have the head/rocker cover - hot oil vapour and the other side you have a cold / damp air from the air filter, where these two meet you are getting a condensation effect.
this is exactly where land rover fit the breather heater units for the Scandinavian/Russian markets
Post #206170 28th Jan 2013 8:30am
Caterham
Idea
aha ! makes perfect sense - thank you.
don't suppose you can tell me what going on with my transfer box can you ?
Post #206173 28th Jan 2013 8:38am
