![]() | Home > 130 > Demo 130 DCHCPU from Land Rover |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
Needs some j-lo type love
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
Gimme please
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
chadjizz Member Since: 25 Apr 2012 Location: sussex Posts: 559 ![]() ![]() ![]() |
good to hear some good things about the 2.2.
i get on with mine. |
RFT Member Since: 13 Nov 2010 Location: Yorkshire Dales Posts: 694 ![]() ![]() ![]() |
Andrew,
I assume it has Continental cross contacts AT's, could you check the handbook and let me know the tyre pressure recommendations. I have put them on my MY10 130 and would like to know the pressures, they have much greater Tarmac contact compared to Michellin OE fit. Enjoy the test drive, glad to see you are making the most f the conditions. Richard 130 Puma HCPU with an Artica 240LR Demountable Camper |
WWA Member Since: 12 Aug 2012 Location: Northumberland Posts: 197 ![]() ![]() ![]() |
Everytime I see a 130 I want one even more!! And RFT, by zooming in on the picture I THINK they are the Goodyear mud tyres on it. I would think it will still have the info you require in the hand book though.
Does it look like they've fitted the longer wheel studs for those rims Andrew or are a couple of threads showing on the wheel-nuts as usual? Steve.
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 ![]() ![]() |
i understand hcpu stands for high capacity pick up but what is the other hc in the title for?
RFT - i have crosscontacts (235/85/16) on my 130 at the moment, came from the factory like that a few months ago. its not stamped in the book, its on the drivers side door piller.
mine tells me - fronts 45 (psi) backs 60 (psi) |
Thanks Chadjizz, what mpg are you getting with yours? I lost about 1.5mpg when I changed tyres, hence why I am trying a few tyre pressure changes.
Giles I thing it is a spurious hc. Richard 130 Puma HCPU with an Artica 240LR Demountable Camper |
cheers RFT - I thought it had something to do with the double cab status (as opposed to a 130 pick up) if you get my drift. my LR knowledge can rest now i know its a typo
RFT mine wouldn't be a good comparison, its a new 130, only just started to loosen up with 2000miles on the clock. the gear box through 2nd and 5th is tight as a nuns c**t still.
i think the best i have got is 400ish miles to the tank. sorry ![]() |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711 ![]() ![]() ![]() |
Sorry my error should be DC to start not HC ![]() DC = Double Cab Its on Goodyear MTR's I will get the tyre info tomorrow and post. Drove to Birmingham today to take Thomas to Willows vets for his check up. First thing the missus said was 'the engine is quiet' |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3153 ![]() ![]() ![]() |
Looks nice. 2011 110 USW
1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
