![]() | Home > Puma (Tdci) > EGR Stuck shut |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
If you have a Bas or alive tuning box they can turn off the egr 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 ![]() ![]() |
Switching off is just stuck shut without a warning isn't it
Clear the code for now and see how it goes. If it comes back on / keeps coming on all the time then it needs replacing. It may also put out some MAF readings incorrectly too as it can alter it a bit. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 ![]() |
Thanks,
Did clear the code. 2nd time I have done this now Hes got a dynachip remap which gives him 450m per tank what ever hes doing. Something must be working right as I cant this kind of mpg with mine If it kicks up again I will have to renew the EGR for him as hes no good with the spanners ![]() 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
With the EGR closed it probably will add a bit of MPG. And changing one been there done that. As normal a proper pain in the a** to get at! _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Simple test to see if the EGR is responding....can you hear the self clean cycle on shut down? Sounds a bit like 5 x chukka chukkas? Also the nanocom is a very good tool but unfortunately does not differentiate between tested and untested dtc's which can lead to serviceable parts being replaced needlessly.
![]() Some random readings from my Puma taken with the nanocom, yet no tested dtc's found when using the MSV2 or IDS straight afterwards! NANOCOM - PUMAENG.APP - PUMA ENGINE fault file 0404 - 73 Exhaust gas recirculation (EGR) control circuit range/performance actuator stuck closed --- 0404 - 72 Exhaust gas recirculation (EGR) control circuit range/performance actuator stuck open --- 0299 - 00 Turbocharger A under boost condition --- 0100 - 29 Mass or volume air flow A circuit signal invalid --- NANOCOM - PUMAENG.APP - PUMA ENGINE fault file 1935 - 14 Brake switch sensor signal circuit short to ground or open --- 02A8 - 00 Cylinder 4 balance - (injector 3) restricted --- 029C - 00 Cylinder 1 balance - (injector 1) restricted --- 02A4 - 00 Cylinder 3 balance - (injector 2) restricted --- NANOCOM - PUMAENG.APP - PUMA ENGINE fault file 0404 - 73 Exhaust gas recirculation (EGR) control circuit range/performance actuator stuck closed --- 0299 - 00 Turbocharger A under boost condition --- 0606 - 49 Engine control module (ECM) processor internal electronic failure --- 0100 - 64 Mass or volume air flow A circuit signal plausibility failure --- 1169 - 00 Fuel rail pressure sensor in range but high --- 068A - 00 Engine control module (ECM) power relay deenergized - too early --- I'm sure that you will agree that some of the above dtc's are a little worrying? Yet the dealer level tools I have never logged the same dtc's as the nanocom. ![]() JMTW ![]() |
