Home > Technical > Problems with headlamp protectors
standard_Man
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tamar Blue
I have Genuine Landrover headlamp protectors on our 110 and one of the passenger side top rivnuts is spinning in the panel and the screw is seized.
What are the options ?? Drill it all out and replace ? How easy is it to go to it from underneath ?
Post #204293 22nd Jan 2013 1:55pm
If you can get a set of molegrips on the rivnut from behind you maybe able to unscrew the bolt as normal and then tighten the rivnut up ...
Post #204296 22nd Jan 2013 1:59pm
standard_Man
How easy is it to get inside of the top outer passenger side wing ?.
Does the arch liner have to come off ?
Post #204303 22nd Jan 2013 2:17pm
Happyoldgit
Been there, done that. The model you have will determine how much potential free space for access you have under the wing via the engine compartment. You might get away with removing the headlamp and bowl assembly and getting in that way - especially if you can get someone with small hands to help! That said removing the inner wing is more fiddly than difficult.
Attempting to drill out the rivnut might work if you can stop it spinning and enlarging the hole in the wing. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #204314 22nd Jan 2013 2:29pm
standard_Man
Its a 2007 110 xs (Puma)
Post #204326 22nd Jan 2013 2:39pm
Happyoldgit
In that case I'd first try removing the side and indicator ligths, headlamp surround, headlamp & bowl and see if you can get someone to get a grip on the spinning rivnut while the screw is undone. Steve.
Post #204376 22nd Jan 2013 5:36pm
standard_Man
Access is the problem, without the headlamp protector removed I am struggling to get the headlight surround etc off.
Post #204384 22nd Jan 2013 6:12pm
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
Can you get a terminal screwdriver behind the guard and tap it into the bulge/ lip of the rivnut and apply some pressure to it while someone else try's to turn bolt head ?
Thumbs Up It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #204426 22nd Jan 2013 8:00pm
Happyoldgit
Oh doh, of course it will hinder it just a bit, sorry for the brain f@rt moment! Embarassed
Are these the perspex protectors do you mean steel headlamp guards? In the past I've drilled down through the screw starting off with a small pilot and applying pressure by one means or another to stop the whole lot from spinning. If they are steel guards you could carefully grind the head off the offending screw enabling the guard to be removed and then the rest of the screw to be drilled out. Steve.
Post #204513 22nd Jan 2013 10:42pm
