Home > Technical > Loose metal noise/rattle when the going gets tough
Puma90man
South Africa 2009 Defender 90 Puma 2.4 Fire LE Vesuvius Orange
I went out on a rather tough 4x4 trail the weekend and heard that each time the drive-train is under stress (like going up a steep hill in a gear that ends up not being strong enough in the end) - that there is a metal clutter/ noise coming from the undercarriage. Is it the prop shafts vibrating? Is it normal? Rolling Eyes
Yeah - yeah - I should have it in the right gear but not always easy if you're hanging on the edge of a cliff....
Post #65618 30th Mar 2011 1:29pm
LESVOSD110
South Africa 2010 Defender 110 Puma 2.4 SW Fuji White
I get something like that on the Puma.Thats were my 90 with a tune v8 make me Laughing Silent grunt!!!! Puma 110 SW
90 V8 SOFT TOP
Post #65626 30th Mar 2011 2:00pm
mse
clutch no 2 for me i think! Mike
Post #65652 30th Mar 2011 5:21pm
Puma90man
Oops - MSE - How will I be able to confirm if there is a problem with the clutch?
Post #65959 2nd Apr 2011 8:53am
mse
All i can tell you is you almost described the noise and conditions i got tha gave me a new clutch (no 2) i think i had 3 in total.
But it all depends on the noise. Mike
Post #65962 2nd Apr 2011 9:06am
Stef M
Belgium 2009 Defender 110 Puma 2.4 DCPU Stornoway Grey
I had this same noise, LR thougt it was the clutch... Turned out to be a heat - shield underneath giving this noise.
I just needed to push it into place again and noise gone... Smile
Post #66028 3rd Apr 2011 11:10am
mse
Hope its the simple solution for you Thumbs Up Mike
Post #66031 3rd Apr 2011 12:33pm
carlaac
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
+1 tighten my bolts up again today after. Was about 2 months since I last tightened them and they were nearly falling out. Although I did a straight 14hrs from Alps to home at 70 on the autoroute. Just the right frequency to rattle them loose.
Post #66090 3rd Apr 2011 10:47pm
Could just possibly be the rear brake rattle feature. easy to test, lightly apply the brake with left foot and see if the noise stops.
More likely to be the clutch I think.
Post #66113 4th Apr 2011 9:42am
ashtrans
Site Sponsor
are you sure it's not the traction control working ?
Dave Dave
Post #66165 4th Apr 2011 5:07pm
Puma90man
Dave
No definitely not traction control. Sounds more like thin metal plates rattling against eachother. I'll go check the heat shield (just not sure why it only rattles when the vehicle is running out of oomph on steep inclines?)
Anyway - any excuse to spend some time under the landy......
Post #66192 4th Apr 2011 8:42pm
Caterham
and.....
Post #203461 19th Jan 2013 10:12pm
ericvv
Post #203464 19th Jan 2013 10:25pm
lrMike
Greece
Had exactly the same symptom on mine and it was the transfer case touching a steel protection plate that I have fitted as extra. The protection plate was bent a bit in the middle between the chassis beams after some playing on deep snow and rocks.
What about that ?
Could also be a failed transfer case mount.
Mike.
Post #204454 22nd Jan 2013 8:52pm
rossy
I asked a similar question about a year ago.
When towing the caravan and pulling away in an inappropriately high gear from low speed (say third instead of second) I can hear a clanky rattle that lasts for about a second or two. It too sounds like its coming from the front prop or diff and disappears as speed increases. I was advised that its perfectly normal under load. I haven't towed since last August and my drivetrain is totally clonk free so hopefully its nothing to worry about Thumbs Up
Post #205658 26th Jan 2013 8:41pm
