![]() | Home > Maintenance & Modifications > Moss / algae in window runners |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
I too had moss cultivating on mine. Decided a cover would be the solution.
More info here: http://www.defender2.net/forum/topic15754.html?highlight=cover If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
try silicone spray, nothing will grow on that stuff
| bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248
Diluted solution of IPA (rubbing alcohol) and water, 25% IPA rest water.
Pour into channels and lightly scrub with an old toothbrush then pour in more solution. Leave for an hour and then rinse with fresh water. Then use the silicon spray. The IPA mix kills the algae Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
| Peter Td4 Member Since: 23 Oct 2010 Location: Antwerp, Belgium Posts: 228
Thanks Bob & BPman,
Same problem here so I'll certainly try that Defender 110 StaWa - Td5 Defender 110 HCPU - Puma Defender 90 Soft Top - Td5 |
| Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
I use the pressure washer, as the Algea only grows on the outside runners on mine.
| Bogtrotter Member Since: 03 Mar 2012 Location: Lincolnshire Posts: 19
Thanks guys...will try the ipa solution. Steve w.
| Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897
I thought 'window boxes' came as standard with every Land Rover.
| WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935
Weedol or Pathclear, or any weed killer spray.
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
| rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1297
I sprayed mine with Polycell Mouldkiller (triggerspray - from any DIY store) last year and it hasn't appeared since
| McGeordie Member Since: 20 Feb 2012 Location: Central Scotland Posts: 220
IPA should work, fine
I use this stuff as APC, All Purpose Cleaner, for mats, and general cleaning, also softening really stubborn grime...it also worked spot on removing Algae from the window seals on a RR Sport, using a soft brush, I used it diluted 1:10, but you could step it up if it was really tough. I'd ass to a spray bottle, soak the areas a few times then use a tooth brush or detailing brush if you have one. |
sorry, meant to attach a link!
Meguiars All Purpose Cleaner http://www.cleanyourcar.co.uk/engine-and-e...d_321.html |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
or you could just go the opposite way and enbrace it:
| lukev01 Member Since: 24 Mar 2012 Location: Bedfordshire Posts: 412
When the moss grows in the window channels of my S2A it prevents the windows from sliding open.
Had you considered that this might be a desirable extra security "layer"? |
