Home > Maintenance & Modifications > Clutch pedal squeak - again
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Hi all,
I recently brought my 110 in for it's 24k service, and one of the most annoying issues was finally dealt with - a persistent squeaky clutch.
The man at the garage told me that he had to lubricate the linkage from above (?), as that was the source of the squeak and that it is a common problem on these models.
The lower spring however still squeaks. It was OK for a day or so, but returned. I hit it with some lithium grease, and this does the trick for a day - but it invariably comes back.
Is there something more robust than lithium grease that will last longer?
Post #54919 25th Jan 2011 12:19pm
Grockle
try silicon spray,it sortred my mates Disco pedal squeek 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #54930 25th Jan 2011 12:47pm
TC
If that doesn't work, take the plate off the top off the pedal box (engine bay, on the bulk head directly above the clutch assembly) and squirt some teflon lube directly onto the master cylinder push rod.
I was squirting GT85 all over the inside of the footwell for a week and getting more and more frustrated, did the above and sorted it instantly. Get a decent platform to stand on though as the lower screws for the pedal box cover are below the line of site, doing them back up is a ball ache if done by feel.
Thumbs Up
Post #54960 25th Jan 2011 5:12pm
eutek
Thanks guys... I'm off to Halfords this evening to get some silicone spray, if that doesn't work I'll try plan B and get that plate off.
Post #54972 25th Jan 2011 6:09pm
eutek
I doused the squeaky area with silicone spray and it helped, but it soon came back.
I realised that I'm partly to blame, as I have been pressing the clutch at slight angle. This must cause the spring to bind a little bit - thus producing the squeak.
I've always driven like this, but the Defender is the first vehicle to complain about it!
Post #55022 25th Jan 2011 9:57pm
mse
My disco brake peddle has just started Evil or Very Mad Mike
Post #55051 26th Jan 2011 12:05am
gtveloce65
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Epsom Green
Clutch pedal squeak (small but really annoying issue) sorted a few warranty trips ago, but coming back again now!!! 1953 80
1965 Alfa Romeo GT Veloce Sprint
1980 Fiat 124 Spider
2008 110xs
Post #56267 2nd Feb 2011 6:56pm
TC
Thumbs Up
Thumbs Up
Post #56270 2nd Feb 2011 7:22pm
Martyn
United Kingdom 2014 Defender 90 Puma 2.2 PU Keswick Green
Removing the several screws out of the clutch master cylinder cover plate and spraying the whole lot inside with deep penetrating spray did it for me. Clutch is now as smooth as silk. Do expect to have to do it again in a few months though, just one of those things. Hop up to stand on essential as previously stated, screws are out of line of sight if stood on the ground.
Stick a cloth under your clutch pedal if your lube is runny - it will run down your pedal to the inside of the vehicle.
I consider myself an auto bafoon and rarely lift the bonnet to look inside but managed this with no issues. Rolling Eyes
Post #203336 19th Jan 2013 3:49pm
CyberCharlie
United Kingdom 2007 Defender 110 Puma 2.4 USW Java Black
6 screws, a bit of patience and an good bit of lubricant and the squeak is gone! Next time it comes back I will flood the compartment with grease. Is there anything bad in using grease in the master cylinder compartment? I believe it should make the anti-squeak procedure more long term.
Thanks guys, ciao Smile
Post #334786 31st May 2014 2:30pm
Happyoldgit
Grease is fine but keep it well away from the master cylinder as it could well mess up the rubber dustcover and seals. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #334811 31st May 2014 4:49pm
ericvv
Post #334819 31st May 2014 6:00pm
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
Wise words.
I've slathered the inside of the box with grease, lithium grease, 3 in 1, WD40, Teflon spray and silicone spray over the last few months trying to stop the squeaking.
Now I'm getting clutch fluid dripping onto the floormat. Could be co-incidence but I doubt it. 2003 Td5 110 Hardtop
Now a 2013 110 USW too.
Post #334859 31st May 2014 8:44pm
CyberCharlie
Cheers guys.
Post #334878 31st May 2014 9:15pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
i did mine in november. but used a few drops of 75w90 fully synthetic gear oil. its still smooth Smile 1953 80"
1987 mini city e
2011 90"
Post #334881 31st May 2014 9:44pm
