Home > Td5 > Starter Motor Removal
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
I have read countless threads across the interweb describing how to do this. Maybe it's because i'm working under the car in the snow when it's minus 2 outside but I can't locate the 15mm "nut from hell"
I've removed all other fastenings.
I'm contemplating undoing the fixings on the fuel cooler to try and get batter access. Maybe even removing the intake manifold.
Any ideas??
Even better pictures!
Post #203035 18th Jan 2013 6:08pm
Porny
Site Sponsor
You need a flexi head extension about 5" long... usually easier from the top.
If you can bump start it, bring it over to the workshop and can do it in the warm.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #203067 18th Jan 2013 6:47pm
excossack
Ahh that little devil!
The way I did it was. 15mm socket on a small extension, put this on from the inside the engine bay looking down (its a tight fit but doable) and then with the socket and extension on, dive underneath and then put the ratchet on
trying not to dislodge the socket/extension.
Its a difficult one to do, even more so in the cold! 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #203074 18th Jan 2013 6:51pm
me@td5.org
Ian
Cheers Ian, It's parked so awkwardly I can't get it moved enough to bump it. I'll battle on tomorrow. I can't find my 1/4 or 3/8 sockets Shocked so have been battling with my 1/2 drive set. Just too clumsy (like myself!)
Post #203085 18th Jan 2013 7:12pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Very difficult, if not impossible, to get at it with a 1/2" drive set, you really need a 3/8" set with a nice long extension and i personally do it all from underneath. The first time i did one was in the snow on a friends disco in the pub car park, it wasnt much fun!!
Pete.
Post #203279 19th Jan 2013 12:11pm
JWL
I did mine with a 1/2" drive last year, IIRC I put a 6" extension on the socket, then a long one and another one and the ratchet ended up near the radiator! It did make I cuss quite a bit but doable Whistle
Post #203307 19th Jan 2013 1:59pm
me@td5.org
I've got to locate the darn nut first. It seems that every pipe and wire that could be run over the starter has been just to make it harder. Does anyone have a TD5 engine out of the car that could be photographed so I can try to visualise it?
Post #203412 19th Jan 2013 7:40pm
