![]() | Home > Puma (Tdci) > WORTH CHECKING |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 ![]() ![]() |
Hi Gil,
cheers for your info ![]() i just had the compression gasket between the windscreen and bulkhead spray painted under warranty (nearside location, adjacent to the internal 3 bolt windscreen bracket) due to corrossion being present. (hope the seats are ok) |
Gil9713 Member Since: 11 Sep 2011 Location: Colchester Posts: 94 ![]() ![]() |
No probs mate. Hope you are well as you must be seeing the snow today in bulk where you are.
Was scheduled to be at Hereford this morning but M4 and the M5 partially blocked, so giving it a miss, as they have given me a crappy Freelander for a week whilst they argue the next move on the Defender, and frankly can't be arsed. Worst L/R I have ever had, and I've had a few, and its only 2 years old..........but I love them ![]() ![]() Yes the seats are great thanks, if they could be getting some use ![]() ![]() |
i think hereford is getting it a lot worse than us (driveable in 2wd with care), but you are right to scratch your trip.
be grateful for a freelander - i got a pug 106 for 3 days ![]() drive it till it rots through and then do a galv rebuild ![]() |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
mine is in for a windscreen leak as well. had to remove the windscreen frame and re-seal everything. mind you, the service guy also said they had 3 more to do as well so we are not the only ones.
Colchester....Para's? BM52
Best Battalion 2 PARA
someone i know in the Rifles would probably argue that point
![]() in my opinion you are all 'the best' cheers from a civvy BM52 |
brother in law got his wings when he was secconded to paras (not sure which regt).
he's in intell but if you met him you would never have guessed; he's just left for 2nd tour of ghan |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1233 ![]() ![]() ![]() |
Hi Gil,
Got exactly the same problem on my 2010my 110csw. Dealer( ![]() ![]() |
Lots of good lads from the Rifles come west and do really well as their fitness levels are good anyway, look at the speed they march at ...................140 paces per minute, sod that for a game of..............
![]() ![]() Getting back to the wagon, they admitted to me last night, (this is Customer Care who I was advised to put some pressure on by my dealer independently) as they weren't getting any answers quickly...........they admitted quietly that there were a lot of people with the same issues. Bodywork badly welded, Fuel rails not doing what they said on the box etc. Some major some minor. The issue is a two year old L/R shouldn't be having all the dramas we are currently having, as they are not a cheap option of a 4WD out there. He then said they are having real problems with motoring organisations alleging that Land Rover have the worst breakdown record at the moment and theft issues. Can't remember seeing any broken down on the side of the road at all! I then launched into him about the theft issues, bonnet wagon etc, and said if they had got it right first time round it wouldn't be on anybody's list to steal it or bits off it ![]() ![]() |
Still got the Freelander from the Dealership. In the past 3 weeks I have been offered 75% of the work under warrantee turned it down waited a week and now they are doing the work that should have been done properly on production FREE...............no brainer.
For those of you that might have a bonnet catch issue, get it sorted quick as to replace and paint a new bonnet is over �2K. Mine started as stated previously with the stake not making connection with the front panel socket, due to the stake being cross threaded on manufacture and finally giving up the ghost, and the bonnet only being held on by the catch.They say it is impossible to weld a new stake in position that close to the bonnet paint. Visavee the battle to get a new bonnet. New Indian bosses who I was told have saved Billions already at Land Rover Jaguar, is that trying to con good honest L/R customers out of their rights!!?? My warrantee isn't worth the paper its written on unless your engine and gearbopx packup.........everything else is a battle The story continues.......... ![]() |
robharvey Member Since: 14 Dec 2009 Location: Durban Posts: 86 ![]() ![]() ![]() |
I had my bonnet replaced under warranty. Exactly same reason as yours - wouldn't close and latch couldn't extend any further.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17913 ![]() ![]() ![]() |
The join between the main horizontal part of the bulkhead running across under the windscreen and the shaped peices at the end (where the screen bottom corners are) is a notorious spot for leaks. The quality of fit seems to be getting worse (perhaps as the tooling is wearing) and even if the weld isn't bad enough to be holed, the misalignment is often bad enough to permit water ingress.
Couple this to the design and material of the more recent windscreen (and greatly inferior) sealing rubber, which is less flexible and has fewer sealing elements, and it is unfortunately far more likely that this area will leak on a recent vehicle than an older one. Usually a healthy dose of an appropriate windscreen sealant into the area will fix the problem, however. |
