![]() | Home > Maintenance & Modifications > Heater upgrade. |
reidzer Member Since: 11 Apr 2012 Location: Aberdeenshire Posts: 12 ![]() |
Has any body seen this for a heater upgrade??
http://www.tukojack.com/livelearnrur4.htm Whats your thoughts? My heater feels like its putting out enough heat but just not fast enough airflow compared to a "real" heater!! |
Puma heaters are more than adequate so presumably you have an earlier model. Certainly worth a try if you have the time, knowledge and inclination. Not sure how well-off you are in Scotland for Pontiac Transports as a donor vehicle though? If you go through life with your head in the sand....all people will see is an ar5e!!
superspoons Member Since: 16 Apr 2012 Location: Herts Posts: 314 ![]() ![]() ![]() |
Now I may be wrong but I'm sure these share many components with the Vauxhall/OPEL 'Sintra' sold in the UK in a fair few numbers... One down the road from me in fact.
http://en.wikipedia.org/wiki/Chevrolet_Trans_Sport Maybe it'll have the correct donor parts ? HTH Cheers, Superspoons |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 ![]() ![]() ![]() |
I seem to remember a while back seeing a similar write up using a mini blower (that was for a series though)
DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 339 ![]() ![]() ![]() |
Another option would be a heater unit from these guys http://www.t7design.co.uk
The large 8.6KW heater would be ideal for winterising a 110 Hard Top |
I can't imagine that there are hundreds of them in Todd's ( tukojack) neck of the woods. He lives in Sweden. Barbara |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2762 ![]() ![]() |
A bilge blower inserted between heater box and wing duct makes a good upgrade as well.
