![]() | Home > Maintenance & Modifications > Alarm remote receiver wire extension. |
totoD110 Member Since: 26 Nov 2008 Location: Manila, Philippines Posts: 86 ![]() |
Thank you much Andrew!
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2067 ![]() ![]() |
Just done this mod and it only took about 15 minutes to do.
Wow, the improvement in distance the remote now works is great! Thanks AndrewS |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8477 ![]() ![]() ![]() |
just found this and think it worth doing, good post Andrew Cheers
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
The range is unbelievable. I did the mod without telling the wife - she came and asked if I had changed the batteries in the remote
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
Hi Derek You sure you connected to the correct wire. ![]() I ran mine up the door pillar under the cover and pushed it into the ceiling space. I also skinned the end as it is on the original wire end, Also soldered the joint and fitted heat shrink. Rgds James |
Braam Member Since: 23 Jan 2010 Location: Centurion Posts: 2 ![]() ![]() ![]() |
Tanks Andrew, mine is sorted
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366 ![]() ![]() ![]() |
Did mine last week, only took 20 minutes. So much better now
![]() 98 V8 Disco |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
Ha ha! I do that too!gives me an extra 20 meters. It works better when it's cold and dry outside though! I doubt it's improving my brain though. ![]() |
Hans Member Since: 12 Jan 2010 Location: Lot, France Posts: 45 ![]() ![]() ![]() |
I did mine yesterday, added some 2m of wire. Great improvement for 0,00!
Thanks! Hans http://www.orlaya.fr |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2509 ![]() ![]() ![]() |
Excellent improvement
![]() ............................................................. Earth first. Other planets later |
Anyone done it with a TD5 yet?
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2684 ![]() ![]() ![]() |
Hi guys,
this issue with the remote, is that on all Puma's or only on certain year models? Reason I'm asking is that I'm about to get a 2009 or 2010 90 soon ![]() |
