Home > Puma (Tdci) > Could a faulty injector...
Slim
2007 Defender 90 Puma 2.4 HT Tonga Green
Hey guys,
My Defender has developed a knocking sound. It started as a tapping sound under load 2,500/3,000 RPM, normally up hill. The noise seemed to develop from a tapping sound to a knocking sound over the course of a few miles. I thought it might have been the Pilot/Spigot Bearing or Clutch as I had just changed them both. So, I decided to opened it up to see if anything was amiss. All was in order, so it went back together. I then drove around two miles before the sound got so bad I had to stop the engine. It sounds as if the big-end has gone.
I have been told by my local Land Rover Specialist that a faulty injector could make my engine sound as if the big-end has gone. Is this possible?
The sound does seem to be coming from the back of the engine.
This post follows on from my post ''Pilot Bearing Issue''
Thanks in advance.
Liam
Post #202464 16th Jan 2013 10:50pm
Caterham
Liam
I hope you get sorted. the only advice I can give you is it would appear my heat shield has been causing me a load of grief. Probably nothing to do with your issues but all I can say is for the sake of a few seconds makes sure the whole of the turbo heat shield assembly is secure.
good luck
Post #202469 16th Jan 2013 10:58pm
Slim
Caterham,
During the clutch change the down pipe/cat came off and back on. The bolts are all present and tight.
Thanks though!
Post #202470 16th Jan 2013 11:05pm
Dieselhead
Injectors can knock badly if faulty
Trouble is you dont know which one it is with out correct test equipment Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #202628 17th Jan 2013 6:14pm
barbel jim
Quick answer is yes - Do you get it at other times ie starting from cold (that was when mine was most noticeable)
Post #202635 17th Jan 2013 6:25pm
Slim
WOOOOOOOOO HOOOOOO! Sorry, can't contain myself!
Short story, No3 and No4 injectors were loose, and bouncing up and down. Tightened them down and all is good. Very Happy
So be aware!
Thanks for the tips guys.
Let there be snow!
Thumbs Up
Post #202778 17th Jan 2013 11:30pm
Dieselhead
Thats worrying but it is a Landrover Laughing
Good you sorted it Thumbs Up Chris
1983 Mini Mayfair
2004 VW T5 Camper
Post #202806 18th Jan 2013 8:12am
Caterham
slim,
great news that its sorted. I'm sure I don't have the same problem however I've got to the point that I want to check everything I can.
was tightening the injectors as simple as it sounds?
Post #204130 21st Jan 2013 11:15pm
Slim
Hi Caterham,
Cheers, I'm well pleased. Very Happy
I didn't tighten it myself but I believe that it is one 8mm bolt per 2 injectors. If you remove the plastic cover then it should be obvious. Be careful not to over tighten them though as the head will be made of alloy. Hope you find the root of your problem soon.
Cheers.
Post #204417 22nd Jan 2013 7:34pm
General Lee
2008 Defender 110 Puma 2.4 SW Bonatti Grey
On my way to check my injectors........but gents,I have similar noise coming from the engine.But as soon as I engage my clutch(step on the clutch), the engine runs lovely.Engine also seems to run good on a cold start.
Post #309797 20th Feb 2014 7:16am
munch90
should really fit new copper washers on the bottom of injectors and have the injector sets checked , esay to remove injectors . if seats are damaged you may need I seat cleaner its like a long reamer bit like a water tap washer reamer .only needs normally a couple of turns to get good seat back .
if there blowing they can build up carbon under the washer and will never seal 100% just by tighten down
if there quite loose you get misfire or not so loose a chuffing sound and smoke from oil filler cap as puma washers are internal
Post #309839 20th Feb 2014 10:11am
Tumich
Czech Republic 2008 Defender 110 Puma 2.4 SW Blenheim Silver
ON the early MOdels 2007-08 were the Clutch plates or sth there bad made
so when its when the clutch is on
than it could be this
Post #309949 20th Feb 2014 4:15pm
