![]() | Home > Maintenance & Modifications > Quality replacement propshaft? |
Please can someone confirm "up to 2A638133" means up to 2002? Why would Paddock's Bailey-Morris prop only suit TD5s up to 2002? I wonder why they don't stock HD props for Pumas?
Okay - enough to think about for a while and loads of good info. Thanks again Gents (and Gentesses) ![]() But shout it at them in German because life is also terrifying and confusing... |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2750 ![]() ![]() |
That's correct yes. |
Thanks for the info Andy - on your and other people's advice, I will be contacting Gwyn Lewis to see if he can help. ![]() But shout it at them in German because life is also terrifying and confusing... |
Thanks guys
![]() That would explain why the vibration improved when I refitted the handbrake drum... Are there 4 possible phase positions or just 2? Otherwise I'll look tomorrow ![]() Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
There are as many as there are splines on the shaft!
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6199 ![]() ![]() ![]() |
It shows this chassis number on microcat too. must be the last Td5 number. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8338 ![]() ![]() ![]() |
the prop is splined so you can adjust the phase by rotating it a spline at a time.
are those angles correct on a puma with the the difference in gbox angle mounting compared to a td5? if you are just trying to see if the rear prop is at fault have you tried removing it and driving without it for a bit? i am guessing you may of as you mention vibration reduced when you refitted the handbrake drum. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Unfortunately, Gwyn Lewis can't do rear props for a 110 Puma
![]() Oh well - plenty of other ideas now - determined to get it balanced and checked in-phase ![]() Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
IKke Member Since: 16 Aug 2008 Location: Brabant Posts: 117 ![]() ![]() ![]() |
There are businesses who specialize in drive shafts and every part that comes with it. I just finished a project with one and IIRC they had spicer quite high up their quality list. Scaling the real deal.
Actually, I must say that Gwyn is an incredibly friendly and helpful guy - I've learned a lot in a very short time, also a bit about how the Puma propshaft was developed by GKN at the start. He was involved. Apparently some testers even refused to drive the test vehicles until vibration problems were fixed
![]() He also confirmed that the Puma setup is "not exactly optimal" which is why GKN had significant problems at first. Apparently the stock propshaft is already semi-wide angle to cope with the standard geometry and lifting a Puma more-or-less demands a DC. As Gwyn seems to be planning on buying a Puma, I hope it will result in even better modified Puma parts ![]() But shout it at them in German because life is also terrifying and confusing... |
