Home > Maintenance & Modifications > Quality replacement propshaft?
ZeDefender
Need some advice please...
I'm looking to try a new rear prop on my 110 Tdci (MY11) to get rid of some shaking.
Paddocks do props from Bailey-Morris and GKN Hardy-Spicer.
Are these similar/good makes - are there others/better?
Cheers for any help,
Matt Tell someone you love them today because life is short.
Post #202025 15th Jan 2013 2:41pm
jst
Bailey Morris are good. also try prop shaft clinic.
personally i would go to gwyn Lewis, http://www.gwynlewis4x4.co.uk/page36.html he will supply what you need at a good rate and he knows his stuff. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #202027 15th Jan 2013 2:45pm
sc70
Wales 2015 Defender 90 Puma 2.2 CSW Santorini Black
I''ll second the above, I always use Gwyn great service at the best price Thumbs Up
Post #202031 15th Jan 2013 2:53pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
yes i am going to replace my rear prop with a bailey morris unit
steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #202037 15th Jan 2013 3:18pm
Retroanaconda
Bailey Morris make a range of "extreme" Land Rover props which are the same as the ones Gwyn Lewis supplies.
Be aware that the UJs are not standard - they're larger and stronger, which is fine until you come to replace them and they're £40 odd each.
Post #202085 15th Jan 2013 6:17pm
jst
£40 you sure? thats not what i pay for the larger ones. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #202105 15th Jan 2013 6:58pm
ZeDefender
Thanks for all the info. It looks as though Bailey Morris is my best bet (as I thought) and as no-one has mentioned GKN Hardy-Spicer I'll steer clear of them.
I asked Paddocks about this one (no answer yet):
http://www.paddockspares.com/wide-angle-pr...rakes.html
But it states "Disc Brakes to 2A638133" - that's 2002 isn't it? Will it really not fit a Puma?
I'm looking for a replacement that is built to finer tolerances and can handle more torque than the stock one. I don't actually need better articulation but I think it will be a useful side-effect. This looks the biz Thumbs Up Tell someone you love them today because life is short.
Post #202108 15th Jan 2013 7:08pm
Retroanaconda
That's what they are here:
http://www.ebay.co.uk/itm/170731718415
I actually bought them direct from Bailey Morris in the end, and I don't remember them being much cheaper if at all.
If you have another source I'd like to know for next time they go.
Post #202131 15th Jan 2013 7:49pm
I suspect that the puma 110 prop is different to the Td5 as the puma gearbox is mounted in a different position, hence the lengh of prop change, eventhough the rear axle is the same.
Td5 and V8 have the same part number. Puma 110 rear is LR010463
I thought GKN made the factory props, so they can't be that bad, can they?
Post #202156 15th Jan 2013 8:27pm
ZeDefender
Is the position of the transfer box between TD5 and 2.4 so different, I wonder? On the 2.4 I have to take the prop right off to get to the handbrake drum - I assumed it was due to LR re-use of parts from the TD5 Rolling Eyes
Basically, I want to try a different (non standard) prop to see if it has any effect on some shuddering/vibration. I've no possibility here to "borrow" one and driving "rear-propless" probably won't help as it will change the resonance of the drivetrain. I already turned my prop through 180 degrees and the vibration got quite a bit better, which is why I hope I'm on the right track.
I figured if I have to buy another prop to find out, it might as well be a bloody good one! That way, if I'm wrong, at least I have something worthwhile to show for it Thumbs Up Tell someone you love them today because life is short.
Post #202179 15th Jan 2013 8:52pm
mk1collector
Would it be possible to get your original prop rebalanced? It may be a cheap way of finding out if that is your problem with the vibration. From what I've seen they just spin your prop up and weld on a weight where necessary.
Post #202186 15th Jan 2013 9:00pm
jst
GKN hardy spicer are good, most use GKN replacement UJs on normal props.
next time i do a UJ i will dig out the MPN. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #202188 15th Jan 2013 9:02pm
ZeDefender
Not so easy round here - can only find one place (miles away) and they want around £100 Shocked
May as well buy one... Tell someone you love them today because life is short.
Post #202192 15th Jan 2013 9:09pm
mk1collector
Blimey
Post #202197 15th Jan 2013 9:17pm
landy andy
I brought my props direct from Bailey Morris. Very nice people.
A mate of mine had a vibration on his Tdci, he fitted new prop, but this did not help, so altered the fazing of the uj's and that sorted his issues, he did this with advice from Gwyn Lewis.
Andy
Post #202202 15th Jan 2013 9:25pm
