![]() | Home > Puma (Tdci) > REDEX |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
Placebo effect mate
Probably agree with you there ! We often see what we want to! An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
sc70 Member Since: 29 Jun 2010 Location: Tregaron Posts: 261 ![]() ![]() ![]() |
Mine never goes any better if I clean it................so I don't bother
sc70
you're right however I generally find an increase in performance is only noticable after the second coat of polish. ![]() |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 ![]() ![]() |
I put some ( a
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8372 ![]() ![]() ![]() |
is that not just because it was a civic? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
stevie d Member Since: 09 Nov 2009 Location: Bishops Stortford Posts: 342 ![]() ![]() ![]() |
Use Two Stroke Oil!
Quieter smoother diesel engines. Steve ![]() Discovery 3 HSE BMW 330i Coupe |
I put some Redex in my Hillman Husky many years ago, cap full down each spark plug hole and a drop in the carb, just like my old man said
If you put any sort of liquid in through the plugholes, you should spin the surplus out on the starter before replacing the plugs. ![]() |
It was a long time ago and I was following the advice of my old man
So he never advised you on the safe use of an axe.....................
My old man had an interesting way of teaching, his family's business consisted of a couple of butchers shops in Birmingham where he served an apprenticeship then national Service took him off and gave him tastes and skills anew. He must have enjoyed himself as he stayed on in the services for a while. Then he went into farm work and used to work on Packington Estate, where Land Rover used to do a fair bit of testing and press days as it wasn't that far away from Lode Lane. He spent some years driving HGV's and all the time we had horses around which were allways part of our life.
As an only child, he was allways imparting me with different skills he had picked up along the way, I could use a steel to sharpen a knife from an early age, a lot slower than him though, I would spend hours chopping logs for the fire and Rayburn, learning as I went along. He was a true countryman and an excellent shot, except in later years when his eyesight started to fade and he left us stranded one night when he put a full choke through my Volvo 145's radiator one night out rabbit shooting! He would show you once and then leave you to it, you either carried on doing it his way or found a way to suit you, he didn't mind as long as the task you were doing got done as fast or faster than he did it. He would have been the first to admit that there is no one way to do a job, it was the end result that mattered. |
Back to redex....
Would double doses of redex each tank full do any harm or benefit? I'm thinking this would be cheaper and perhaps as beneficial as diesel ultimate? |
