Home > For Sale & Wanted > For Sale - Land Rover logo puddle lights - 3 SETS LEFT!
Page 2 of 3 <123>
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
Hi I don't know if I like them or not
Can't make my mind up
But I think I'd better have a set please Rolling with laughter Rolling with laughter Rolling with laughter
Pm sent It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #201514 13th Jan 2013 7:08pm
TD5_dan
2001 Defender 110 Td5 CSW Java Black
Lol, they are like marmite, but are actually useful as a puddle light, surprisingly bright. Remember they are only 2 wires so maybe people could think of another clever use for them somewhere on a defender?! Confused
All PM's replied too 2001 TD5 110 County Station Wagon - sold
1970 Series 2A Station Wagon
1970 Series 2A hard top
1960 Series 2
1972 Series 3
Post #201520 13th Jan 2013 7:26pm
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
Hi Dan, You have a PM, sent you 2 payment's, decided to treat the wife to a set too Thumbs Up Optimists say the glass is half full..
Pessimists say the glass is half empty..
Engineers say the glass is twice the size it needs to be!
Post #201623 13th Jan 2013 11:07pm
TD5_dan
Sent out 7 sets today to forum members still have a few of these left! 2001 TD5 110 County Station Wagon - sold
1960 Series 2
1972 Series 3
Post #201666 14th Jan 2013 10:08am
yorky
England 2007 Defender 90 Puma 2.4 SW Java Black
TD5_dan wrote:
Hi will post up a couple of pics later where I fitted them, I had made a small hole in the bottom of the door and popped the lights in. They are around 6cm in depth and 2cm in diameter. Then it's a case of wiring a live and switching via the door pin earth.
Hi Dan,
These look good. Where did you take the live feed from? 90 XS
Volvo V70
Post #201722 14th Jan 2013 2:34pm
TD5_dan
I have a secondary alarm on my vehicle so just wired the live into this behind the clocks the passenger side will require the wires to be extended if you can't find a live over that side of the vehicle. They are very low current with small wires so can safely tap into any live feeds nearby. Simple but very effective they were better quality than I was expecting! 2001 TD5 110 County Station Wagon - sold
1960 Series 2
1972 Series 3
Post #201725 14th Jan 2013 2:58pm
yorky
OK, can't resist, think I better have a pair if you've got any left? 90 XS
Volvo V70
Post #201730 14th Jan 2013 3:28pm
TD5_dan
I do have few sets left. If you send a paypal payment will get them in the post Very Happy 2001 TD5 110 County Station Wagon - sold
1960 Series 2
1972 Series 3
Post #201731 14th Jan 2013 3:34pm
yorky
OK. PM sent 90 XS
Volvo V70
Post #201732 14th Jan 2013 3:41pm
Go Beyond wrote:
Could you post pictures of where you've fitted them please
The doors seem to narrow to fit these, can you post pictures please ...
Post #201733 14th Jan 2013 3:42pm
TD5_dan
I will do Matt took a couple of pics last night of them they are a tight fit in my 2001 doors but do go. The actual housing is about 23mm in diameter. Mine were a nice tight fit so you dont have to use the retaining nuts that come with them but could use a little sikaflex to seal bond the units in. Will get the pics off my phone when I get in. 2001 TD5 110 County Station Wagon - sold
1960 Series 2
1972 Series 3
Post #201736 14th Jan 2013 4:01pm
Thank you Thumbs Up
Post #201737 14th Jan 2013 4:03pm
K9F
Dan could you please confirm there was no prompting from me to use the 'S' word. Great stuff. Thumbs Up Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #201738 14th Jan 2013 4:14pm
TD5_dan
Right heres some pics of them fitted, sorry about the quality they were close ups with a phone camera and i was shivering because it was so bloody cold when i fitted them!
Vehicle in pics is a 2001 TD5
Basically the units are around 26mm with the lip at the lens however they require a 23mm hole for the body of the light to fit into (This hole saw is included and seems pretty good quality) just dont drill to fast as it melts the tips of the saw.
I trimmed a small section out of the bottom door rubber and then drilled through the bottom section of frame then you need to slide the drill/hole saw out in your drill to get the depth to drill through the top section of frame. Obviously paint where your holes are and i took opportiunity to wax oil inside door frame, then push the light unit through. They come with securing nuts but these would require the top holes to be slightly bigger so you can drop the nut in the frame and twist the light to tighten, however with the thread and the fact i made nice clean holes my lights were a really tight fit and when finally fitting them i ran some sikaflex around lip and then finished off with a bead around the top of the light unit to just seal off and make it look smart.
Just remember to make sure your window is fully down and unit will clear it and wires are going to need to be extended to follow all existing looms of car then earth onto your door pin switch and permanent live.
I didnt find them hard to fit just a little time consuming to get it looking nice and neat as it would have left the factory just take your time, i used a hole in the door frame which was already there from factory and just enlarged that when i did mine.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2001 TD5 110 County Station Wagon - sold
1960 Series 2
1972 Series 3
Post #201820 14th Jan 2013 7:11pm
TD5_dan
993porky you have a PM 2001 TD5 110 County Station Wagon - sold
1960 Series 2
1972 Series 3
Post #201934 14th Jan 2013 11:31pm
Page 2 of 3 <123>
