![]() | Home > In Car Electronics > Td5 90 CSW audio upgrade/soundproofing. |
| barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1455
Put the open cell under the sides, but reading other post decided against open cell in other areas as it is prone to water!!! Dynamat is water proof, and i have sealed the seams with aluminium waterproof tape so any water should sit on top. I decided on rubber matting as practical, wipe clean, and I have sealed the rubber to the dynamat with sikaflex. Hope fully it will all be water tight and I should be able to use the hose to clean it !!!
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
If your going to be hosing out the back you don't want any open cell foam as it will act like a sponge.
Thats why Its only on the H/t Sides
Ahh I see, I thought you meant wheel arch sides for some reason
trapped water was the whole reason for choosing dynamat. I looked at the noisekioller kit, but thats open cell. The landy is used as a work vehicle, so it has to be practical.
