![]() | Home > Maintenance & Modifications > LED positioning |
| XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632
Seen something very similar on one of 'Bolt on bits' ads on eBay, and wondered the same thing.
I dare say you could make the wiring a bit tidier by running it in the recess under the arm and then through the hinge. Probably quite easy to adjust as you can just stick your arm out the window. Pete |
| Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478
they look good but would be better in the mirrors, now thats gave me an idea
www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
| sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455
DLRs in the mirrors would look good if they where small ones you could also fit heated mirrors while there
But the spots would be a DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
| yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 714
They are Rigid Industry Duallys the brackets work really well for adjustment.
| SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527
Thought of getting 2 of these as reverse lamps but unsure if to have them switched or just linked to existing reverse lamp?
Possibly overkill and |
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584
Visio X Soltice there is
Please note that basically additional driving white lights have to point forward. However lights pointed at 45 degrees is good for picking out tracks in forests at night time Under vehicle lighting regulations you are only allowed TWO reversing lights. We have two work/camp lights on the back of our 110's. On back of black 110 two Vision X Soltice giving out 1800 lumens. These are switched independently of reverse light. Hence they are illegal for road use as reversing lights due to number of lights. They are good for reversing up our drive between dry stone walls etc. Obviously I do not use tem on road Brendan |
| BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785
Unless some muppet is knocking on you back door that is 2011MY 110 XS USW Black |
| boode Member Since: 11 Apr 2012 Location: Devon Posts: 438
With the Duallys producing 1300 Lumens each ( or 2600 for the D2s ) I think you would get too much glare off the wings if mounted on the mirror stalks - a narrow pencil beam light might be OK
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
certainly look like rigid duallys to me ... 4 led version. why would you mount them on the mirror stalks ? the RI dually's are excellent lights, like Gavin said, you can have flood or pencil beams, and white or amber leds. like Gavin, I have ambers mounted into my D44 HD bumper. RI also sell coloured lenses for these in red, blue and amber. at night even the ambers are very bright and enough to drive without headlights on |
| All times are GMT |
