Home > Technical > Durite Crimping pliers
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
Does anyone in the south have a pair of these they could either A) post to me, I'll pay for postage and return them, or B) I could post some wiring with a return postage paid envelope? or C) let me use them if you are local.
Thanks in advance.
Post #201303 13th Jan 2013 12:28am
I've got crimpers here that go up to 70mm cable. In Swindon though.
Post #201312 13th Jan 2013 1:56am
K9F
Handy tool to have and dependant on size of crimping obtainable for pre-insulated crimps for about £20-£35 is it not worth buying a set perhaps? Cheap automotive ones are also available form Halfords obviously.
Do not have Duralite but do have access to others.... DMC, Daniels, Raychem and Amp.
If it's something larger I will be able to help. Option B would be best. Any possibility of a better description of what you want to achieve? (Size of cable, type of termination etc. etc.) PM if preferred.
Thumbs Up
http://www.google.co.uk/#q=durite+crimping...mp;bih=575 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #201325 13th Jan 2013 9:28am
appaloosadude
Embarassed
http://www.hgvequipment.co.uk/070351-durit...-6332.html
These, I thought that durite only had one type of connector. How wrong. I don't really want to fork out £50 for a tool I will probably never use again.
Post #201334 13th Jan 2013 10:04am
K9F
The equivalent DMC tool I have does not have the size range of the Durite one depicted. Mine is 18-24 AWG. Why not take the cables into an automotive/motorcycle workshop and get them to crimp them up for you or ask to 'borrow' the tool and crimp them up yourself on their premises? I've done that in the past when desperate.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #201337 13th Jan 2013 10:15am
My mistake.... read the link to the type of crimpers you need... not hulking great bolt on lugs like mine does Laughing Laughing Laughing
Post #201356 13th Jan 2013 10:55am
K9F
No offence Jim but having been based at Lyneham not a million miles away from Swindon I thought you may have been talking about hair crimpers.
Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #201367 13th Jan 2013 11:06am
Lorryman100
You can get that tool for less than a tenner, wouldn't rely on it on a daily basis but for seldom use it may be a good option for you.
http://www.wholesaletoolwarehouse.com/elec...mping-tool
Brian.
Post #201373 13th Jan 2013 11:12am
K9F
Brian,
That's not the right tool. The Duralite one depicted crimps the contacts that go into the DIN type connectors and/or the rear of relay bases with a double crimp action. It crimps the conductor and rolls two tabs over on the back of the crimp that grips the insulation too. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #201374 13th Jan 2013 11:19am
Lorryman100
I suspected that Mal, but it was more to show that you can get a cheap, from China copy of a tool if you do a bit of searching that may actually do the same job for a lot less money. Thumbs Up
http://compare.ebay.co.uk/like/29078316241...amp;crdt=0
Brian.
Post #201376 13th Jan 2013 11:23am
K9F
Very fiddly and time consuming process but if you have the patience and eyesight you can do without the tool and crimp the Econoseal and Superseal terminals without the expensive crimping pliers using a pair of ordinary fine needlenose pliers. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #201380 13th Jan 2013 11:27am
I always solder on my econoseal connectors.
Makes them much (IMO) stronger and a better contact
Post #201414 13th Jan 2013 2:52pm
ZeDefender
+1 Thumbs Up Tell someone you love them today because life is short.
Post #201423 13th Jan 2013 3:51pm
Lishlandy
England 2012 Defender 110 Puma 2.2 X-Tech LE Orkney Grey
I have a teng tool crimper, feel free to pop over and borrow it. ===================================
Steve
90 xs sw in Stonoway Grey - Sold
110 USW X-TECH
Post #201427 13th Jan 2013 4:33pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
http://www.amazon.co.uk/gp/product/B00386Z...02_s00_i00
I use this laser one - works well. Less than £12 delivered.
Post #201678 14th Jan 2013 12:00pm
