![]() | Home > Maintenance & Modifications > Side hinged tailgate and swingaway? |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6723
I'm looking at replacement options for my aging and cracked cut-down safari rear door.
Has anyone got a Mantec swingaway carrier in combination with a side-hinged tailgate type door? The swingaway must move with the door, not be a separate pin/latch only operated from outside. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
Surely you just need a carrier that will work for a standard door? It won't know that there's nothing above the waistline. If you fit side hinges to a standard drop down tailgate then I can see that their may be a need for a small amount of adaptation where the carrier would bolt to a full height door, but I can't see it being much more than some spacers to take up the difference between the tailgate panel and where the door skin would be.
Alternatively, if you use another cut down door then it should be plug and play. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584
The central plate off the wheel carrier is located just below the waist line. If a standard tailgate has been converted to a side hung door then it has an external central reinforcing rib. This means that some spacing will be required and possibly some reinforcement on the inside.
If it is a home cut down of a rear door then it would depend on how the top has been finished off/reinforced. Safari Equip do a rear half door, I will have to find some pictures/information about it. Brendan |
I'm keen to go down the route of a "proper" NAS type side-hung tailgate rather than another sawn-off safari.
A Mantec swingaway is, I think, the only carrier which fits with my combo of 50th rear step, my setup of NAS rear lights and the soft top. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
| lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 764
I've recently turned my tailgate into a side hinged gate...Having it resprayed in the end of the month
Click image to enlarge I'm also interested in what would be the best swingaway option to fit in the future (If I ever go to Morroco and need more room inside the load area)! Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
| GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387
I found this, only last night
http://www.expedition-equipment.com/produc...e-defender |
Doesn't look like that opens with the tailgate though, it's pinned on the left.
2015 D90 XS SW |
| GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555
Is it not pinned to the latch on the left (the one that keeps the tailgate shut), if so, surely when you un-latch the tailgate, the tailgate and the carrier will swing open ? An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
Yes, but as I said originally:
This is because my 90 has seats in the back and I don't like the idea of the rear door only being able to be opened from outside. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
Ooops. My bad.
No probs, I'm just being specific/picky
2015 D90 XS SW |
| Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678
I have a Safari equip wheel carrier on my SVX alike, works perfectly with the NAS step
| Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015
Have I read this wrong.... or are people over thinking this.
Do you just want a SW rear door, cut down to size, put capping along the top and then fit a Mantec spare wheel carrier? I think Safari Equip do something like this?
Glyn |
| JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412
Are you looking for a genuine NAS type rear door Martin? John
http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
