Home > Tdi > Flat Battery and a spinning starter when jump start
pdennis30
Hi I have had my defender for about 6 months now , I tried to start it today after 4 days of non use and the battery was flat not even any dim dash lights , I connected some jump leads, and as soon as I did I could hear a motor spinning , it turned out to be the starter motor, no keys were in the ignition at the time ,had been driving through some puddles and a ford the last time I used it , is it related ? Do I need a new starter or just clean up the old one
Thanks in advance
Paul
Post #201009 12th Jan 2013 1:31am
pope10001
United Kingdom 1992 Defender 90 200 Tdi HT Zermatt Silver
Sounds like it might possibly be the same problem that I had. A problem with the key and barrel where the key doesn't return to the correct position leaving the starter motor spinning whilst the engine is running. It burnt my starter motor out. I had to replace the starter motor, mega fuse and barrel to rectify the problem. I believe there was a special service action or a recall ref. this problem. HTH
Mark. Wink
Post #201017 12th Jan 2013 8:58am
pdennis30
Thanks for that , could explain why the alarm started to go off recently because of the battery drain , what's the Mega fuse by the way , also had a problem with engine running on after I turned off the ignition , thought it was stop solenoid but could be ignition barrel ,
Thanks
Post #201094 12th Jan 2013 2:49pm
K9F
Mark. Wink
Think describing your latest post Mark's hit the nail right on the head. You could possibly consider fitting an X-Defend barrel lock at the same time for peace of mind. Two birds.....one stone!
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #201096 12th Jan 2013 2:51pm
pdennis30
Thanks , never heard of a xdefend barrel will look into that
Paul
Post #201097 12th Jan 2013 3:03pm
K9F
Paul
Welcome! Fitted mine only yesterday! Here you go...... Thumbs Up
http://www.defender2.net/forum/topic17090.html?highlight=x+defend If you go through life with your head in the sand....all people will see is an ar5e!!
Post #201103 12th Jan 2013 4:20pm
pope10001
The Megafuse is a (I believe) 500?amp fuse that is contained within the big plastic positive connection on the battery. Mine blew when i had the problem.
Mark
Post #201168 12th Jan 2013 7:27pm
pdennis30
Thanks guys for all you help , oh good it's going to snow tomorrow and my defender isn't working!!
Post #201196 12th Jan 2013 8:22pm
pdennis30
Ok the saga continues , removed all wires from back of ignition switch and made no difference so have ruled out ignition problem . Starter still span when battery connected , until it eventually would spin no more , so suspected Solenoid fault on starter , removed old starter and replaced with new one , old starter confirmed not working by direct connection with jump leads. , now engine did turn over for a bit , (battery is good by the way )but would not start , as soon as battery is connected ignition lights come on including glow plug light , without the key in the ignition !,but nothing electrical woks at allso suspecting earth problem , in process of cleaning up replacing neg feed from battery to gearbox via chassis, are there any more earth points , have seen reference to bulkhead earth point on other posts , is this the one near the top on the drivers side with small black cables , or is there another one ? Is there an earth from gearbox to engine or chassis to engine , a location would be helpful as I have some under body protection fitted so its not easy to see everywhere .
Thanks
Post #202243 15th Jan 2013 10:39pm
pdennis30
Problem found , the loom that comes into engine bay on top of gearbox , was shorting out , now how to repair it ! It's in a nice awkward place , and it's cold outside !
Thanks for everyone's suggestions
Post #202636 17th Jan 2013 6:25pm
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
I had a simmilar issue where the vehicle (110 TD5 at the time) was in for a service at the main dealers and we picked it up & drove it to a fancy dress party with 8 people in that night.
All my passengers were rather well oiled at 3 am, so I brought the vehicle round to the front of the club, and turned it off while they all piled in.
Went to start and nothing happend! starter was dead as a dodo...! Sad
Called the AA and the man came out and after 30mins scatching his head and poaking about in the cold - found that the power lead to the sarter had come off - 2 mins later we were on the road again ! Very Happy
Mind you he probably had few giggles at a landrover full of drunken St Trinians school girls on steriods! Embarassed Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #202665 17th Jan 2013 7:23pm
