Home > Td5 > TD5 Battery Help Please
highbayrack
United Kingdom 2002 Defender 110 Td5 CSW Zambezi Silver
I think its about time to replace the battery on the wifes 2001 Defender. I'm fairly sure its the original factory fit, so it's not done bad but it wouldn't crank the car over this morning. Can anyone tell me please what type/model I should be looking for and where's a good place to get one at a reasonable price. Thumbs Up
Chris MY02 Defender 110 CSW air con, electric windows, privacy glass, traction control, abs,tow pack, parking sensors,rai,special rear seat conversion.
Post #200459 10th Jan 2013 10:18am
The battery on my 2002 Disco2 packed up last year, and I replaced it with another Genuine Parts one from LR (Delphi IIRC), on the basis that the old one had lastest 10 years without any problems whatsoever (despite running a Warn XD9000i), and also I couldn't find anyone who made one of the same spec.
It also avoided any issues with charging rates (I believe that the originals are lead calcium batteries which require a higher charging voltage than lead acid).
The part numbers for Disco2 and Defender batteries are the same, by the way.
It might also be worth bearing in mind that the standard Defender battery vents any hydrogen discharge through a pipe passing through the floor, and I haven't seen provision for this on any aftermarket battery (although it probably isn't essential).
Post #200469 10th Jan 2013 10:55am
highbayrack
Cheers Blackwolf, I've got to go to the dealer later on another matter, i'll see what they have Thumbs Up MY02 Defender 110 CSW air con, electric windows, privacy glass, traction control, abs,tow pack, parking sensors,rai,special rear seat conversion.
Post #200475 10th Jan 2013 12:04pm
BigRuss
What about and Odessy PC1500? Russell
2011MY 110 XS USW Black
Post #200512 10th Jan 2013 2:03pm
Laurie
My original battery lasted for six years.
Fitted a genuine part. Now two years old and going strong.
Post #200520 10th Jan 2013 2:19pm
JWL
Looked through my service history the other day and I'm still on my original clutch and battery, not bad for 150,000miles and 10 1/2years.
Now that's Censored it Rolling Eyes
Post #200535 10th Jan 2013 3:48pm
Laurie
How long does an exhaust last?
At nearly eight years, mine's looking good as new.
Post #200540 10th Jan 2013 3:57pm
JWL
I took my middle box and downpipe with cat off last year and they look as good as new apart from having to cut the joining bolts which start to corrode when you take the spanner of them at fitting time Rolling Eyes
Seems to be that if they are used and not parked up then they last longer.
Post #200541 10th Jan 2013 4:11pm
