Home > Puma (Tdci) > brake issues HELP!!!!
skiboy
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Galway Green
My 2010 puma has started hissing from the pedal, I've never noticed this before today, i didn't seem to have any braking issues today on the way home from work, but found it when i was parked on the driveway turned the stereo and heater off,
the pedal can be pumped to 'hard' when the engine is not running, but after starting the engine, you can push the pedal down until it goes hard then it slowly creeps down ?? all the time with this sound of a bellows being pumped ??
i've checked the fluid, there is good level, no leaks and no bubbles in the tank, i had the wagon serviced only 5K ago ?
is this normal, ( i hate to say but i just checked my wife's golf and that seems to be the same although it has 130K on the clock and is Censored )
advice please hive minds
Post #200329 9th Jan 2013 8:24pm
skiboy
anyone ?
sorry for the swear word, didn't even know i had put that in ?
Post #200341 9th Jan 2013 9:07pm
bwanashamba
2011 Defender 130 Puma 2.4 HCPU Alpine White
Check the brake booster,your brake fluid resovoir is attached to it, you cant miss it. The booster has a large rubber grommit attaching a plastic tube to the body of the booster, check this grommit is not leaking air by having someone pump the brake peddle while you listen.
Hope you come right Smile
Post #200453 10th Jan 2013 10:06am
jst
its fine.
where you describe the brake pedal going down after starting the engine etc, it should do that.
stop worrying. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #200638 10th Jan 2013 9:27pm
