Home > Td5 > Oil Catch tank - breather hose
Page 2 of 2 <12
quentin
Australia 2004 Defender 110 Td5 SW Alpine White
You should be able to get them in UK, the Provent200 is made by Mann+Hummel
https://www.mann-hummel.com/company/index....rec_no=192
if all else fails Western Filters http://www.westernfilters.com.au at least you wont have to pay VAT
c'mon fellas , I have to get almost all my Defender bits shipped from UK to Australia, just need to know what you want a few weeks prior & its a not issue,
Post #199806 7th Jan 2013 10:01pm
Les Brock
Hi all,
First post on here so be gentle Laughing
You can pick them up on ebay very cheaply as they are popular with the Golf and Scubby clans
I seem to have picked up 3 this way Whistle Rolling with laughter
Dearest was £26.00 plus £5 postage
Regards
Les
Post #199917 8th Jan 2013 1:46pm
Is this a worthwhile mod on the 2.2 engine or does the different design of the PCV make it redundant?
Post #199983 8th Jan 2013 5:54pm
sherifsalem
Portugal 2005 Defender 90 Td5 ST Java Black
Ordered my Provent yesterday from RepublicSales US via Ebay.....Now i have to get into the hoses issue
Therefore i should be looking at the following from all what i read:
1- 1/2" (13mm) x 40 cm - (this is for the oil drain)
2- 3/4" (19mm) x 1 meter - this from the crankcase to the filter inlet & from the filter oulet to DCV)
WHAT ARE THE MINIMUM SPECS OF THE HOSES TO BE USED
3- 1/2" Brass drain tap ( for oil purge)
4- Provent 200 inlet and outlet are 1" (25mm) therefore you will need a straight hose reducer on both inlet and oulet
5- clamps
6- Heat protection foil
I will try to use the existing hose that is connecting currently the crankcase to the DCV ( it is quite new and looks fine, in this case i will need one silicone to connect to the DCV)
Quentin i think i will go for your Filter location, just one question! are you confortable with the heat projected by the engine on the filter or you feel it is not really a problem?
What are your thoughts on this ? because steve keep it far from the engine!
thanx Happy Travel
www.thegippo.wordpress.com
Post #200206 9th Jan 2013 10:26am
sherifsalem
One more curiosity i have Quentin, i did take out my TD5 engine cover as well but why is it that you took out the turbo and exhaust protection ?
Any benefits coming from there?
Looked in the engine bay yesterday and saw it was a pretty solid well fitted protection plate with many screws around Smile Happy Travel
Post #200207 9th Jan 2013 10:34am
quentin
No issues at all with heat,
the Provent appears to be made from Polycarbonate, plus its on the cold side of the engine.
Had no issues with my insulated hose over the exhaust manifold melting either, drove Sydney to melb 850klm on a 40+ c day last week & worked a treat.
I took the Engine Acoustic cover off because it really does not quieten the engine anyway. The Turbo cover went in the rubbish bin at the same time, The turbo heat shield has no thermal efficiency at all, The bottom edge of mine was rubbing into & cutting the oil cooler to EGR cooler water return pipe on the back of the engine (Which I have now sealed off after EGR removal) With the engine cover & turbo sheild off you can easily see any problems before they become major - like leaking manifold, broken studs, bulging oil cooler pipe & its oh so much easier to get at the oil filter.
Also in this hot country the hot air can escape from around the engine faster - probably not so important in UK
pic below of the part of the turbo cover that was rubbing thru the water pipe on the back of engine. my advice - throw that cover as far as your able
cheers Don
Post #200227 9th Jan 2013 11:47am
sherifsalem
Crystal clear....
And the hoses Quentin any specs? what type of hose you used? does it have to be resistant to oil or it is enough to be resistant to heat and pressure?
Che Happy Travel
Post #200233 9th Jan 2013 12:50pm
quentin
firstly must be resistant to oil, secondly heat, thirdly pressure.
I used 7/8 oil transfer hose , and wrapped in heat insulation shield
this type of stuff would do - (not sure about the diam tho , would pay to ask them)
http://www.ebay.co.uk/itm/Goodridge-06-AN-...45fed62e64
good luck with the project.
Post #200234 9th Jan 2013 12:56pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Agree with Quentin, get rid of the cover and shields. They do very little, I have lots of reflective tape but I only have it on because I had some.
The only area I would protect is the water hose at the front of the head, this went very crusty on mine as there is no protection as standard but needs some.
Look quite similair dont they Quentin?
Post #200242 9th Jan 2013 1:32pm
sherifsalem
Steve your engine bay is superbly clean....what is your secret!!!! lol
I think this is becoming the ultimate Crankcase Breather one stop forum.....
Steve i yet again noticed that you have defenitely capped off the end of the hose running from the filter outlet to the DCV ( actually you said it before) and i can see that you blocked the DCV (valve) with something shiny.
Cant really tell what it is!!! can you enlight us with your solution. Happy Travel
Post #200260 9th Jan 2013 2:58pm
Steve B
Hi,
It is just a piece of aluminium turned down with a top hat and a little swage to help retain it once the clip is tightened.
Steve
Post #200265 9th Jan 2013 3:33pm
sherifsalem
Got that for you:
the conversion sizes for the hose Internal Diameter is as follows :
-04 AN 536 = 6.35mm
-06 AN 536 = 9.52mm
-08 AN 536 = 12,7mm..................(1/2")
-10 AN 536 = 15.87mm
-12 AN 536 = 19,05 mm................(3/4")
Ebay.co.uk list a similar hose by Aeroquip which is called AQP Socketless Hose, they list both the 1/2" and 3/4" sizes.
The max pressure is 250psi (17bar) and the temperature range for oil is -49oC to +150oC. The hose uses push fittings just like the Goodridge.
The prices are as follows -
1/2" I/d £12.56
3/4" I/d £14.76 Happy Travel
Post #200497 10th Jan 2013 1:00pm
MalteseRover
Malta
ok.. seems like i am about to revive an old topic. ..
would a 2ootdi breather/separater do the trick? The Pro 200 seems like a great thing but a bit expensive for me right now.
should i give the land rover item a try? not much oil passing through right now in my TD5 but wish to minimise it.
regards
joseph
http://www.ebay.co.uk/itm/Land-Rover-Defen...1131246719
Post #635085 2nd Jul 2017 1:38pm
Page 2 of 2 <12
